Grey & Davis aftermarket Starter/generator
Jeff
First Name: Jeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by Jeff » Sat Feb 07, 2026 12:04 pm
I sourced this unit for a guy in India who has a 1915 T and wants to add a starter, but also wants everything period correct.
I got it from Dodge Riedy who got it to me here in Idaho a few days ago.
The bendix was completely stuck at first. After a bit of coaxing with penetrating oil, dunk tank and carb cleaner, I got the bendix working again. It's now fully operational and ready to be installed on a car. I'll soon be sending it to the port of LA where it will go into the trunk of another car and then inside a container to make its way to Bombay India.
You can see it operate in the video I made.
https://www.youtube.com/watch?v=UmQoHCPe_vE
What an ingenious device! Quite the conversation piece.
It drives a gear on the crankshaft like this
Jeff
"The trick to creativity is knowing how to hide your sources..." Albert Einstein
www.modeltregulators.com
www.modeltstarters.com
Re: Grey & Davis aftermarket Starter/generator
Post by DanTreace » Sat Feb 07, 2026 12:56 pm
Neat accessory for sure. Have seen one in Jack Putman’s place on his T
Wondered how fan was fitted, on Jack’s the large gear has pulley for fan belt. Instruction page notes T fan bracket remains in place.
