Crankshaft Endplay
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Crankshaft Endplay
Post by CatGuy » Thu Feb 12, 2026 6:09 pm
I’m looking into why the magneto isn’t working on my ‘26. I’ve checked the post and it was fine. I just now checked the endplay and it seemed fairly significant to me. It’s an exaggeration, but I would say it’s nearly 1/8”. That’s just a guess. The black book talks about an oversized bearing endcap. Do they still make those? Lang’s only shows a crankshaft shim that I suppose goes on the outside of the engine and might need to be machined. I don’t have a way to do that.
Re: Crankshaft Endplay
Post by speedytinc » Thu Feb 12, 2026 6:28 pm
By "dosent work" you mean 0 output? That's not an end play problem. A wide magnet gap would mean weaker output.
With the clutch disengaged, you would have a reasonable output.
A 3rd bearing cap fitted with the correct thrust would be the fix for excessive fore & aft crank movement. Ready to pull the motor to replace that 3rd main? Whall your motor is apart, you can replace the field coil (presumably) with a good one & recharge the magnets etc. to get your magneto working again.
The Langs Brass shim goes behind the pulley. It is attached by the 2 bolts on either side of the crank front timing gear cover.
The mount is slotted. If some material is needed removing, it can be done with a file or sanding disk.
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Thu Feb 12, 2026 6:42 pm
I have used the pulley shim on one of my cars for years with great success. It was a good temporary fix that kept the magneto functioning until the engine finally got to the point where I pulled it for a total rebuild.
CatGuy
Last Name: Hunt
Post by CatGuy » Thu Feb 12, 2026 6:46 pm
I guess I assumed from the Black Book that if there was too much space the magneto wouldn’t work at all. I know I’ve not gotten a light to work by hooking it up to the post and when I flip it over to ‘MAG’ it immediately dies.
CatGuy
Last Name: Hunt
Post by CatGuy » Thu Feb 12, 2026 7:01 pm
Would it be possible for you to post a picture of it installed?
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Thu Feb 12, 2026 7:52 pm
Have you verified that there actually are magnets on your flywheel ? The past 40 years or so, it’s been popular to think a Model T can run 70 mph with modern traffic if only all that unnecessary revolving weight (flywheel magnets, cast iron pistons, etc.) can be eliminated. :roll:
Get a horse !
Post by Allan » Thu Feb 12, 2026 8:42 pm
How was the 1/8" end play measured? If it was done by levering on the fan pulley and engine block, some of it could be due to a loose fan pulley. Whatever, 1/8" is excessive. If it is due to wear on the thrust face on the third main, I would suspect that the crankshaft flange is also worn. That rules out re-working just the bearing thrust face. The crankshaft flange would need to be ground and trued for a new third main cap to be made to suit.
CatGuy
Last Name: Hunt
Post by CatGuy » Thu Feb 12, 2026 8:54 pm
Good point. I hadn’t thought of that.
CatGuy
Last Name: Hunt
Post by CatGuy » Thu Feb 12, 2026 8:57 pm
I may have to check again. I had the pry bar between the engine and lower pulley.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Thu Feb 12, 2026 9:02 pm
Has the magneto ever worked in this car?
I would test the magneto before going too far.
https://www.mtfca.com/discus/messages/5 ... 1470945248
It is possible to have a shorted magneto post so that is a quick test.
The last one I found was a tiny bit of wire caught in the spring, never found out where it came from.
I have seen several mag posts that do not connect well in certain spring positions so check that while you are at it.
There are lots of wiring connections inside the ring coil that can fail.
Magnets can discharge or be broken
The wiring up through the switch can fail
Parts can be missing
While crankshaft end play should be addressed it may not be something to fix today.
Sometimes you wait until there is another reason to have the engine out.
Main Bearing Caps:
Langs no longer carries re-babbitted caps. You have to get them from your favorite babbitt shop or Rons Machine https://www.facebook.com/RonsMachineShop/
The thrust is always made oversize and has to be hand fitted.
The diameter is cut to several undersize values but needs to be final fitted to your crankshaft.
They are not drop in parts.
Crankshaft End Play Shim - 3030SHIM:
This is also oversize and needs to be cut to fit.
It will take multiple attempts to get it right.
The only one I ever installed was not in there long.
It was in there long enough for me to find out the engine was totally worn out and needed rebuilding anyway.
Find all the problems and then determine the way you want to fix your car.
Sometimes it's run on battery until it's time to fix it "right".
Mike
Last Name: Hatch
Post by Dan Hatch » Thu Feb 12, 2026 10:17 pm
It amazes me that even after 100 years bandaids for Model Ts still sell.
Post by Scott_Conger » Fri Feb 13, 2026 8:48 am
Dan
Band-Aids still sell because surgery is expensive!
CatGuy
Last Name: Hunt
Post by CatGuy » Fri Feb 13, 2026 11:32 am
Main Bearing Caps:
Mike
I actually thought it did when I first got it, but if so it was brief.
CatGuy
Last Name: Hunt
Post by CatGuy » Fri Feb 13, 2026 5:08 pm
Possibly a really dumb question. It’s an early spring in Iowa so I’m out tinkering on the T and getting sun. I thought I would check the continuity from the MAG post to the other end that goes on the terminal block. I haven’t disconnected any wires, but so far I have continuity from the post to ANY wire on the terminal block. Is that correct? Doesn’t seem like it.
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Post by Bill Robinson » Fri Feb 13, 2026 7:01 pm
Here is a real good possibility- if you or someone else has done some electrical repairs...or testing.... on the vehicle's electrical system, and somehow, either knowingly or accidently allowed DC current to enter the flywheel and/or magnets (or mag post) a bad mistake has been made. DC current entering the magneto system (even slightly) will KILL the magnetism of the flywheel magnets-- and it only takes a slight flash. The magnets can be re-magnetized but you will need the Black Book for info. Better yet- contact your local Model T Club.
Your club might have a Magneto University that you can attend, like our club had when we were young. See the photo.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Fri Feb 13, 2026 7:56 pm
When the magneto wire is hooked up it is grounded on the other end and has low resistance.
The lighting circuits (3 of the screws) will have low resistance bulbs also connected to ground. This might show up as a short with two low resistance parts in series. Incandescent bulbs are low resistance and LED's are high resistance and polarized.
That leaves the Battery terminal and Generator terminal.
I am racking my brain on these two circuits but I can not find a definitive answer.
There are multiple different cutouts and regulators and some might pass power back through maybe.
The battery terminal could sense through the battery causing a false reading maybe.
There is also the world of different types, makes and models of meters that could be used to get the reading adding another variable.
Back feeding does weird stuff. Think about what happens when a multiple bulb fixture looses it's ground.
This is an example of why it important to isolate circuits when testing resistance.
The magneto resistance should be about 1/2 ohm so it will look like a dead short.
If the magneto post is shorted it is hard to meter read since 1/2 ohm is about the same as 0 ohm to most meters.
I will reiterate that if the wiring was shorted with a quick flash it will discharge the magnets and "kill" the magneto.
The magnets can be recharged in the car, if you follow the correct procedure.
As with most everything the devil (and problem) is buried in the details.
I don't think testing / checking is done yet.
Mike
CatGuy
Last Name: Hunt
Post by CatGuy » Fri Feb 13, 2026 9:19 pm
Is the way the junction block wired on page 43 of the Black Book the way all years are supposed to be? Mine is wired up a little differently.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Fri Feb 13, 2026 10:05 pm
Not all Model T's are wired the same
See
https://mtfca.com/phpBB3/viewtopic.php?t=2960
https://nebula.wsimg.com/bfee1cac0d0763 ... oworigin=1
and I use
https://www.texastparts.com/mm5/merchan ... ory_Code=z
Everyone has their favorite drawing and accessories are custom wired.
I'm sure others will send their favorite wiring diagrams also.
Mike
CatGuy
Last Name: Hunt
Post by CatGuy » Sun Feb 15, 2026 3:49 pm
I checked a brand new ignition switch that I have, but haven’t installed. I got completely different readings with the continuity meter. Checking the old switch (new not original) I can put one lead on the ‘BAT’ and the other on any one of the other screws and I have continuity from. That doesn’t seem right, does it? The new switch doesn’t do that.
Post by Scott_Conger » Sun Feb 15, 2026 4:16 pm
Mike Silbert:
I very much suspect that your new switch is laying on a bench and has nothing connected to it and thus checks out correctly
Similarly, I very much suspect that your old switch is still in the car and is connected to wiring of unknown condition or correctness
If my suspicions are correct, then refer back to the quote from Mike Silbert - meaning that as a start, each individual circuit at a very minimum, needs to be checked for isolation and ground
CatGuy
Last Name: Hunt
Post by CatGuy » Sun Feb 15, 2026 4:33 pm
Mike Silbert:
That is the way I’m currently testing it. I will try it the proper way next.
CatGuy
Last Name: Hunt
Post by CatGuy » Tue Feb 17, 2026 7:09 am
I took the wires off the switch and tested it. It tested fine and normal. I am going to replace it as it turned so hard that it feels like the key will twist off. I’m not sure what to test next. Everything (except the magneto) works as it should. Lights go on and off as normal.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Feb 17, 2026 7:36 am
Model T switch tumblers were made from pot metal that often swells and gives problems after the last 100 years.
Add a bit of rust on the steel parts and it gets stiff.
Careful lubrication and working it can sometimes bring it back around, be careful not to break it.
If the tumbler does need replacing it is not a quick / easy job but possible.
And watch out, the replacement tumblers don't just drop in and need some rework for a proper install.
No matter what you do having a good functioning switch is important to reliable operation.
While it is apart, check the continuity of the magneto contact (inside the hoggs head hole) to ground and cleanliness/conductivity of the magneto post.
It unscrews from the top of the hoggs head to get in there.
That will tell you if there is a chance of life in the magneto.
Mike
CatGuy
Last Name: Hunt
Post by CatGuy » Thu Feb 19, 2026 2:54 pm
I pulled the magneto post yesterday. I’ve had it off before. It was clean and had continuity. I tried putting a scope in the top of the transmission to see if the magneto is actually there, but it was inconclusive. It’s really not visible unless you take the hogshead off, I assume?
Post by Scott_Conger » Thu Feb 19, 2026 3:06 pm
With apologies: I misread an earlier post and gave poor advice due to that, and have now removed my advice due to it being erroneous
Post by speedytinc » Thu Feb 19, 2026 3:39 pm
When you remove the mag post, you would see a lead button that the post spike contacts. It's centered in the hole & not very deep.
When you put the mag post back you will have to push it down on the lead button, compressing the spring.
Its obvious if there is a field coil or not. If you can push your scope down thru the mag post hole, there is no field coil.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Thu Feb 19, 2026 4:31 pm
This following discussion shows a lot of pictures of what the magneto looks like inside
https://www.mtfca.com/discus/messages/1 ... 1264263362
Here is a Borrowed picture from the post above
CatGuy
Last Name: Hunt
Post by CatGuy » Thu Feb 19, 2026 5:45 pm
I definitely saw that button. I couldn’t get much farther with the scope. So, I at least have a Mag….of sorts.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Fri Feb 20, 2026 4:38 am
You can see it better with the top cover - the one above the bands - removed.
That's also the place to look to align the magnets for re-magnetising.
Post by Scott_Conger » Fri Feb 20, 2026 1:53 pm
Honestly, if the crankshaft has 1/8" of play, or anywhere near that, the Magneto is not going to power the car, so any time poking around looking for magnets could really be put to better use drinking beer.
The Forum has a great propensity to typically send you down rabbit holes by the time there are 6 postings or so. At some point someone is going to ask if you've checked the rear end for babbit washers and at that point you know the thread ran its course several weeks prior.
Nice weather is on its way, so suppress the urge to poke around and start enjoying the car - magnets or not, the fix to your problem is either expensive or labor intensive (and sometimes both), so just Put the new switch in, drive it on battery.
Post by speedytinc » Fri Feb 20, 2026 2:21 pm
If there was really 1/8" play, wouldn't the magnet keepers have already crashed into the field coil?
Post by TXGOAT2 » Fri Feb 20, 2026 2:28 pm
I'd think so.
Post by Scott_Conger » Fri Feb 20, 2026 3:30 pm
If wear must always be TOWARDS the coil ring and it MUST therefore crash, then why exactly would a shim between the front of the block and the back of the fan pulley pulling the magnets closer to the mag coil be such a successful fix for the last 110+ years?
The answer is, of course, despite the fact that wear SOMETIMES causes magnets to rub the mag ring, SOMETIMES it doesn't. And that SOMETIMES happens so frequently that there is a solution to that particular problem that has been around for 110+ years.
BTW, I seriously doubt that there is 1/8" play...movement that can be witnessed by eye - excessive, 1/8", probably not.
Post by TXGOAT2 » Fri Feb 20, 2026 4:00 pm
When the clutch is held in neutral, doesn't that pull the crankshaft and flywheel toward the back of the car, and away from the coil ring? When the clutch is engaged, which it normally is, isn't the crankshaft free to float forward and back within the thrust bearing clearance? If that's so, I'd expect the balance of thrust face wear to be on the forward thrust face, with very little wear occurring on the rearward thrust face, so the danger of the magnet retainers hitting the coil ring is very low. If I had excess play, I'd buy the inexpensive adjustable shim that goes on the front of the engine, install it loosely, then have someone pry the crankshaft forward to its limit, then set the shim to leave about .005 clearance, tighten everything up, then re-check the clearance. If OK, crank the engine by hand for several revolutions. If no interference, start it up and let it warm up. If OK, then try out the mag.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Sat Feb 21, 2026 7:42 am
I completely agree with Pat, above.
You only get wear on the rear face of #3 main which might lessen the magnet clearance when descending a hill in high gear.
Post by Allan » Mon Feb 23, 2026 6:37 am
Something is not making sense to me, but that's not unusual. Chris says the back of the no 3 bearing cap wears, and that lets the flywheel close down the magneto gap.
Then Pat suggests fitting a shade tree thrust washer at the front to effectively hold the flywheel closer to the coilplate.
Both "fixes" bring the flywheel closer imminent contact with the coilplate.
A worn thrust surface on the rear cap can be repaired by "soldering" babbit material to the cap flange and hand working it back to fit. If it is done with a nil clearance to fit, it will also compensate for wear on the crankshaft flange once fitted in place.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Mon Feb 23, 2026 9:19 am
Allan,
While the rear of the #3 main bearing is not the only face where it wears, it is where the majority of the wear occurs.
The crankshaft thrust surfaces also wear but not very fast.
The clutch spring in neutral, low, and reverse is pushing it forward with 90 to 110 lbs of pressure, hopefully.
In high gear the crankshaft is "floating"
So as the thrust wears the magneto clearance will both reduce and enlarge at the limits of travel.
Given this is not supposed to be very large magneto gap to start with it is amazing that we rarely ever hear about the magneto parts hitting each other in high wear engines.
Ideally you would add most material at the back and a little at the front.
Pushing it forward can be risky and pushing it rearward is safe but might reduce the magneto output too much.
This is a decision that has to be made by the owner.
The theory of the front crankshaft end play repair shim, fitting a new rear cap, soldering the cap, sliding the cap, adding an internal shim or any other fixes is that it will not push the crankshaft any further forward than it will already have been when running before the fix, probably.
If the magnet plates do hit it is expected the driver will notice noise and the repair is done to accommodate this.
If they do hit after a repair the hope is that the engine will lock up and be noticed before any real damage occurs.
Without actually checking the gap after the repairs are done there is no way of knowing exactly where it is located anymore.
It really is a gamble with decent odds of success.
All of the fixes short of a total refit are just a patch.
These repairs have been done since day one because most of the time they work.
It is a risk vs reward scenario just like many others that are done all the time.
The risk is low and the reward could be very great.
And if the car is hardly ever driven, it could be a repair that outlasts the owner.
Your concern of "imminent contact" is real and is called the risk in this situation.
Mike
Post by Scott_Conger » Mon Feb 23, 2026 10:09 am
It is no sin to not understand the function of the transmission fully, or even if you do understand, but don't take a moment's reflection of what you know about how it goes together it can become confusing and sometimes even harder to describe.
Take a long look at this picture, knowing that the lever that compresses the spring is fastened to the hog's head and in no way is a counteracting force on the spinning transmission. As the spring is compressed backwards (to the rear of the car) when in neutral (or reverse), I may not be understanding plain English - and if I am not, my apologies, but where is this "pushing it forward" effect in neutral, low, and reverse coming from?
It's been several years since I did my last transmission, and perhaps I am just becoming senile...if so, I'll happily accept correction, but from my experience, memory, and knowing how things go together, it seems to me that just the opposite is happening.
The clutch lever pulls back on the collar depressing the spring and releasing the clutch...the transmission assembly and thus the crankshaft is pulled back...the front of the rear main is supporting/constraining the load and thus the wear occurring on that front face of the rear main bearing inevitably leads to an increased clearance between magnets and coil.
photo credit: Herm Konhke
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Mon Feb 23, 2026 10:34 am
Allan wrote:
"Something is not making sense to me, but that's not unusual. Chris says the back of the no 3 bearing cap wears, and that lets the flywheel close down the magneto gap"
No, I was making the point that the rear face only suffers - and then not very much - when descending a hill in high gear. The main source of wear is the strong spring pulling the crank rearwards when high gear is disengaged. And that causes wear on the front face of the rear main, and hence a bigger gap between the coils and magnets.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Mon Feb 23, 2026 10:37 am
Scott, if I’m understanding you correctly, you’re saying compressing the clutch spring by its normal leverage point in the hogshead is actually a force moving the transmission away from the magneto ring ? Seems right to me.
Get a horse !
Post by TXGOAT2 » Mon Feb 23, 2026 11:55 am
What I posted:
"When the clutch is held in neutral, doesn't that pull the crankshaft and flywheel toward the back of the car, and away from the coil ring? When the clutch is engaged, which it normally is, isn't the crankshaft free to float forward and back within the thrust bearing clearance?" /////
Looks like it's best to avoid keeping the car in "neutral" with the engine running unless it's necessary to do so.
Post by Jerry VanOoteghem » Mon Feb 23, 2026 12:28 pm
How are you figuring that descending a hill in high gear causes more wear than in other scenarios?
Post by TXGOAT2 » Mon Feb 23, 2026 1:13 pm
Chris wrote:
"You only get wear on the rear face of #3 main which might lessen the magnet clearance when descending a hill in high gear"
I think confusion is centered here.
In fact, the FRONT thrust face of the REAR main bearing is loaded when the clutch is disengaged. The magnets would exert some pull toward the front of the car, but I don't think it would be enough to seriously affect thrust face wear. I believe that the majority of the front-facing thrust face wear occurs when the clutch is held in neutral with the engine running, and thus the forward-facing thrust face of the bearing wears fastest, and thus the risk of the "shade tree shim" remedy bringing the magnet retainers into contact with the stator is very low.
In my opinion, going uphill or downhill would have no significant effect on the crankshaft position, since other, stronger forces are acting on it besides gravity. Removing the rear main bearing cap and adding material to the front thrust face, the one that faces the front end of the car, could restore the original magneto air gap if done correctly. You'd have half of a new thrust face, which could last a very long time if the car was handled correctly.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Mon Feb 23, 2026 6:20 pm
Forum Members,
I need to confess that I have been thinking about this backwards for about 50 years since I was a kid.
Now I understand why magnetos do not hit on badly worn engines.
Which side wears makes no difference to how I drive and fix my cars so my misunderstanding just kept continuing on and on and on.
I try to make my posts as accurate as possible since this forum is used as a reference for many people and many years.
This time I made a mistake and thank you Scott for waking me up to what is really happening.
So this afternoon I went through how the thrust forces work in a Model T transmission and came up with this:
When you push the Clutch Pedal down it pushes the Clutch Spring (#3340) rearward compressing the spring.
The back of the Spring is locked by the Clutch Spring Support (#3341) pushing it rearwards
The Clutch Spring Support is locked to the Driving Plate (#3321) by the Clutch Support Pin (#3342) pushing it rearwards.
The Driving Plate is bolted to the Brake Drum (#3311) pushing it rearwards.
The force moves to inside the of the Brake Drum riding on the Transmission Shaft (#3331) and it is stopped by the Driven Gear Washers (shims #3320).
The Washers get jammed up against the Transmission Clutch Disk Drum (#3332)
The Clutch Drum is locked to the Transmission Shaft (only in thrust but not rotationally) by a light press fit and the Transmission Clutch Drum Set Screw (#3334) pushing it rearwards.
The Transmission Shaft passes through the transmission and flywheel to be bolted to the rear Crankshaft flange pushing it rearwards.
All of these forces are pushing rearwards once the Transmission Clutch Release Ring (#3400) starts pressing rearwards all the way to the crankshaft main bearing front thrust surface.
Hopefully I have cleared things up and not made them worse.
I have found that normally by the time the thrust is bad on the crankshaft, the diameter is bad also.
Mike
Post by speedytinc » Mon Feb 23, 2026 9:09 pm
I understand the theory & practice of the clutch pulling the flywheel away from the field coil.
I have seen many used cranks that had a good deal of wear on the crank flange side also.
Could it be, the magnets also have a propensity to pull the flywheel into the field coil from the magnetism?
Or is it dirt & grit that works its way into the rear thrust surface also?
Post by Scott_Conger » Mon Feb 23, 2026 9:20 pm
John, I think it's all of the above, compounded by having very minimal thrust surfaces on the rear main bearing shell and not fully around the entire bearing. Converting the rear main bearing to receive a full thrust fore and aft is one of the biggest things a person can do when attempting to build a bulletproof engine.
Post by Allan » Tue Feb 24, 2026 1:17 am
Things must be different in the US model
T's. Here in the southern hemisphere the crankshaft, flywheel and transmission assembly form one big, heavy unit. Regardless of what is pushing what, the only way the crankshaft and flywheel assembly can close the gap between the flywheel and coil plate is if the rear thrust face on the cap is worn. Wear on the front of the cap would allow the gap to widen.
I am unfamiliar with US T motors. Our Canadian blocks have no thrust faces on the rear main bearing. All the thrust, either way, is taken on the beaing cap faces.
Am I mistaken again?
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Feb 24, 2026 10:57 am
Allan,
Wear from the clutch spring pressure will wear the front thrust surface (I was wrong earlier).
This will make the magneto gap wider.
It also will naturally wear forward by some amount. The evidence of this is left on worn and scored crankshaft flanges.
Why this happens and how much happens we can debate about for sure.
The block of US engines does not get babbitt thrust faces when done in stock form.
Some rebuilders will cast the block to have thrust faces like the cap has giving more thrust surface for a longer life.
The thrust surfaces of the 3rd main cap have the thrust surfaces and not the block (in stock configuration).
See this link for a picture viewtopic.php?t=30490
Mike
Post by TXGOAT2 » Tue Feb 24, 2026 11:01 am
I have been under the impression that the rear main bearing cap comprises 50% of the rear main bearing.
Post by TXGOAT2 » Tue Feb 24, 2026 11:09 am
I would think that a full 360 degree babbitt face on the forward facing thrust surface would be a worthwhile modification to delay wear affecting the magneto air gap. I would also think that it would be prudent to configure the added upper forward thrust face babbitt with an oil groove to assure that the main bearing got plenty of oil. Ford may have chosen not to make a 360 degree rear main thrust face in order to assure that the major load surface of the rear main got plenty of oil. I believe that with modern multigrade oil, an oil groove in the added upper thrust face would be sufficient to assure rear main bearing lubrication.
Post by TXGOAT2 » Tue Feb 24, 2026 11:57 am
An engine with a sprung crankshaft or a misaligned crankshaft flange would tend to wear both thrust faces excessively. A flywheel assembly with lateral imbalance would do the same. To minimize general wear, good balance and true-running parts are essential. When the magneto is producing current, it imposes drag on the crankshaft rotation. When the engine is stopped, the magnets will pull the crankshaft forward, but not with any great force. When the magneto is making current, the windings energize and become magnetic and the winding pole pieces are also magnetized. I'm not sure whether this would add to or subtract from the forward pull of the permanent magnets on the flywheel and crankshaft. Scored bearing surfaces typically result from lack of oil, poor quality oil, dirty oil, or all of the above.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Tue Feb 24, 2026 12:04 pm
It's the only case where anything is pushing the crank forward by more than the small magnetic pull - in this case a small gravity force. Much less than the rearwards force when holding low gear or neutral.
Post by TXGOAT2 » Tue Feb 24, 2026 12:15 pm
There are good reasons to minimize the amount of time that the clutch is disengaged with the engine running, so far as is practical. If you use low gear a lot, or often need to idle the engine in neutral, it might prudent to install the shade tree shim before problems develop. Having additional bearing surface could be expected to reduce wear.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Feb 24, 2026 12:58 pm
I put Babbitt thrust surfaces on at least one engine I poured.
I don't remember which one(s) it was though.
To do it you have to remove material from the block to have a thick enough thrust bearing surface.
The stock block is not that much smaller than a finished bearing length.
And since they are not tinned in place (stock style) some mechanical system needs to be also added (pins)
Unless you go to the extra work to tin the block like this
https://www.mtfca.com/discus/messages/8 ... 1534382014
See the picture included here for 3rd main block length vs crank thrust length.
https://www.mtfca.com/discus/messages/2 ... 1204385306
Adding the thrust surfaces to the Model T block is a debated topic see this
https://mtfca.com/phpBB3/viewtopic.php?t=40498
Ford added the thrust to the Model A block but that is a higher speed, higher power engine.
The first Model T blocks did not have babbitt in the block, it was only in the caps.
My opinion is that without good reason there is no need to go to the extra effort to add babbitt thrust to the block.
From what I typically see on well worn engines the diameter wears close to the same rate of the thrust wear.
This means by the time the thrust is worn out often the diameter is worn out also.
If you are building a "monster" motor then there might be a need for the extra thrust as part of the complete package.
A well done stock motor will outlast most of us with normal maintenance using modern oils and sane driving.
At least until the crank snaps...
Others will have different opinions
Mike
Post by TXGOAT2 » Tue Feb 24, 2026 1:36 pm
A tinned block would be ideal. Short of that, the added thrust face would need to be thick enough to resist heating up or cracking from mechanical stress.
Post by TXGOAT2 » Tue Feb 24, 2026 2:37 pm
Ford stated that the magneto air gap should be between .025 and .040. Crankshaft end play should be .002 to .004.
My end play looks to be more like .010, using the eyeball gauge, so the magneto air gap may be in the borderline range. Since I have an aluminum crankshaft pulley, I don't think I can use the shade tree shim. The engine crank-starts easily on magneto when warm, but not so easily when it's been sitting/////
I tried measuring the crankshaft end play with an outside caliper and a micrometer. Best I could tell, the end play is around .008. It may well be less with the engine warmed up.
Post by Allan » Tue Feb 24, 2026 6:37 pm
Pat raises a good point. For a thrust face on the bearing in the block to be effective, the block would have to be "tinned" like rods are. This would require a very different way to pour the main bearings. In standard T engines the main bearings are not tinned to the block. They are peened in place and held in place by the spuds on the poured white metal filling the holes in the block. To pour these bearings like rod bearings would require considerable more preparation and pre heating to get the babbitt to "take."
