Model T TT 5th wheel or ?
Topic author - Posts: 4677
Here’s a photo of what looks to me an early version of the so called 5th wheel. If it is was it a company made or was it available from a body maker. Learning something new about heavy TT Truck use.
Re: Model T TT 5th wheel or ?
The clue to that one is on the building. It allows lengths of timber to be carted which otherwise would not fit on a TT, regardless of the weight of the load. Other lumber merchants are likely to have similar units.
It appears to be a 1924 to 1927 TT with Ford supplied C-cab. Also equipped with a fifth wheel hitch which was a bit unusual still at that time, and special adjustable trailer for hauling lumber. The trailer axle and wheels with the "crib" for holding lumber slides along the long pole to adjust for the length of the lumber to be hauled.
I wonder what the pole was made of? Wooden pole? Or steel pole?
kelly mt
- Last Name: Kelly
Yes, TT's have 5th wheels.
The Sibley lumber truck in this article still exists. It was on dispaly at the Piquette Plant for some time.
https://www.autoweek.com/car-life/class ... r-company/
Last edited by Jerry VanOoteghem on Sun Mar 01, 2026 2:18 pm, edited 1 time in total.
PorkChops
- First Name: P
- Last Name: Chops
- * REQUIRED* Type and Year of Model Ts owned: 1924 Tourer
Interesting to see an early jinker. We used pretty much that same design to haul casing & other oil rig stuff in Indonesia in the 90s.Wayne Sheldon wrote: ↑Sun Mar 01, 2026 12:11 amThe trailer axle and wheels with the "crib" for holding lumber slides along the long pole to adjust for the length of the lumber to be hauled.
Mike Silbert
- First Name: Mike
- Last Name: Silbert
As seen @ Hershey 2023
Mike Silbert
- First Name: Mike
Mike Silbert
- First Name: Mike
Mike Silbert
- First Name: Mike
Mike Silbert
- First Name: Mike
