Removing Battle Locking Steering wheel, help needed
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Post by Jack Putnam, in Ohio » Mon Mar 02, 2026 8:59 pm
I'm looking for the secret to remove the steering wheel lock from the column. It was made by the BATTLE LOCK COMPANY and of course the key is long gone. I cannot see any pins that could be keeping the lock in place. Some paint does remain that could be hiding a pin. If anyone has any knowledge on how to separate mechanism from the column please share. The gears at the top of the column need to be checked and greased
Mike Silbert
Last Name: Silbert
Re: Removing Battle Locking Steering wheel, help needed
Post by Mike Silbert » Mon Mar 02, 2026 9:42 pm
While I am not familiar with that model sometimes the tumblers need to be removed first to get access.
When I buy a car with a missing key here is what I play with.
Sometimes it can take a long time but usually is rewarding, eventually.
bobt
Last Name: Thompson
Post by bobt » Tue Mar 03, 2026 5:57 am
Question. When you say locking, is it locked or is it freewheeling? bobt
Post by Jerry VanOoteghem » Tue Mar 03, 2026 6:23 am
Let's see some views from the bottom side.
Loftfield
First Name: Thomas
Last Name: Loftfield
* REQUIRED* Type and Year of Model Ts owned: 1912 Touring, 1912 Express Pick-up
Post by Loftfield » Tue Mar 03, 2026 7:51 am
Hi Jack,
Any decent locksmith can make a key for you, more $$$ but less stress than attacking the mechanism. I have one of those on one of my cars, let us know how you get it off.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Mar 03, 2026 9:29 am
This may or may not be helpful here but some thoughts:
There has to be a locking mechanism somewhere so the question is where.
Is it hidden under the lock tumbler?
Is one(s) of the plate rivets longer making a locking mechanism?
I would measure a stock gearbox and figure out where around the housing it has to be located.
Do the plate rivets even line up correctly?
Here are some links to various pictures to maybe give some ideas.
https://www.mtfca.com/discus/messages/3 ... 1377609837
https://www.mtfca.com/discus/messages/7 ... 1503209674
https://www.mtfca.com/discus/messages/2 ... 1172706748
https://www.mtfca.com/discus/messages/8 ... 1523226902
https://www.facebook.com/groups/Fordmod ... 3429915548
And be thankful you are not dealing with one of these steering wheels
https://www.mtfca.com/discus/messages/7 ... 1511281484
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Tue Mar 03, 2026 10:04 am
Look for a set screw.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Tue Mar 03, 2026 10:05 am
Look for a set screw. Perhaps under the nameplate.
Post by Jerry VanOoteghem » Tue Mar 03, 2026 11:12 am
I see some odd discolorations here, located 180 degrees apart. Locations of hidden pins? If so, they're likely driven out from the bottom, (hence my request for bottom end pictures).
Post by speedytinc » Tue Mar 03, 2026 12:13 pm
I also saw the one on the right also. Pin locked. One way. You will have to drill them out.
It wasn't made to be removed once installed.
Post by Jerry VanOoteghem » Tue Mar 03, 2026 12:20 pm
If it's like a FOX steering wheel lock, (and some others), the pins will drive out from the bottom. Look up from the bottom of the housing for small notches along the threads that screw the device onto the gear case. In the case of the FOX mechanism, only a very slender pin punch will work.
Post by John kuehn » Tue Mar 03, 2026 2:38 pm
Unless the lock is broken internality it can be picked open. Use some type of light lube like Kroil or WD-40 to loosen the pins or wafers in the lock. If you can see the lock pick set that Mike S posted use one of the picks that’s starts with the one that’s third on the right or some the others from there and “rake” the pins back and fourth several times. That will get the pins internally loosened up. Once that’s done use one of the tension bars shown and a pick and start to move the cylinder with the inserted bar. It should begin to start to turn . Keep doing it and it should open. Good luck. It’s not hard to do and once you do it you usually can open any door, tool box lock and etc using the same technique.
Yes locks should be lubed with graphite but if the pins are stiff Kroil will loosen them up. Dry the lock out and then lube with graphite after it’s opened and cleaned out.
Post by Jerry VanOoteghem » Tue Mar 03, 2026 3:11 pm
Where has the OP stated that the unit is locked??? He seems to just want it removed from the column.
Post by Allan » Tue Mar 03, 2026 5:33 pm
Tapered pins were commonly used for various applications. Stewart speedo swivels had tapered pins to hold the drive gear end in the potmetal housing. If you try to drive them out the wrong way you will do damage. If there are pins, make sure any attempt to drive them out considers the possibility of a tapered pin.
Post by John kuehn » Tue Mar 03, 2026 5:43 pm
A close reading says the key is long gone so the assumption is that it’s locked by the post. 💡
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Mar 03, 2026 11:13 pm
I do not know the operation, installation, or removal of that particular model steering wheel lock so this is purely thoughts.
We have 2 possibilities here:
1) The motion is locked and the steering wheel can not turn. There appears to be a key number on the tumblers so that can help getting a new key.
2) The motion is free and they just want to remove it from the column.
The OP is not really clear on this question.
If I were designing a steering wheel lock and I wanted to lock it onto the steering column very securely I would hide the locking mechanism inside the housing lock tumbler hole.
This would require a key and removal of the tumblers in order to access the area to be able to remove the parts.
Maybe I am designing a system that is too secure?
Maybe it is there, and maybe not, but if I could not find another answer I would remove the tumblers and look.
Until it is proven exactly what is going on and how it is built and how to remove it, all of this is only speculation.
The original poster was looking for ideas and that is what people are presenting.
I hope once it is removed there will be a follow up post so we can all learn from this issue.
Mike
Post by Scott_Conger » Wed Mar 04, 2026 9:29 am
In my line of work, that would be considered a "clue" as to whether the mechanism was locked or not.
Not that it makes one whit of difference to anyone at all, nor to getting it off as is the point of the thread, but my bet is that this thing is unlocked and the steering gears presently operate as designed, key or no key.
As far as getting it off, until the back side is shown as Jerry requested, we're all pretty much guessing, and guessing usually solves nothing.
Last Name: Hatch
Post by Dan Hatch » Wed Mar 04, 2026 9:38 am
Zoom in where the circle is. A pin maybe? Just above the tag.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Mar 04, 2026 12:08 pm
Hi Jack,
The procedure is call "impressioning" a key. The trick is finding an experienced locksmith these days who knows how to do it, as most older generation locksmiths have retired or gone to that great keyboard in the sky. Most current generation so called 'locksmiths' only know how to duplicate a key on a machine. A decade ago, I needed this done and was lucky to find a local locksmith who could, and did, do it for me, and his charge didn't break my bank account.
Post by Scott_Conger » Wed Mar 04, 2026 12:15 pm
Making a key solves the problem of locking/unlocking the steering wheel; there is only a very negligible chance that a key is going to lead to removal of the device for the purpose of servicing the grease, and that is the problem that Jack is asking help for. The great majority of these things are semi-permanently installed via mechanical jamming with pins, as other posters have suggested.
100 years after installation, these old steering lock devices are nearly 100% of the time, a damn nuisance. I feel for you Jack.
South Park Zephyr
Last Name: Francis
Board Member Since: 2022
Post by South Park Zephyr » Wed Mar 04, 2026 1:22 pm
I sent the pics to a locksmith friend.
He said most likely the tumbler will need to be removed, and a key might be needed to do so
He has worked. On two Guardian wheels I have that came without keys. The cylinder had to come out in order to get the the attachment hardware that held the wheel together
Hope that helps.
Scott
First Name: Jack
Last Name: Putnam
Post by Jack Putnam, in Ohio » Wed Mar 04, 2026 10:54 pm
I don't know if you call it locked or unlocked but the steering wheel does turn and steers the car. Fwiw.
Pins have been located by wire wheel paint removal..
Thanks for all the advice.
Post by Allan » Wed Mar 04, 2026 11:15 pm
I'd say the wheel is unlocked if you can still drive/steer the car. In the locked position you are likely not able to turn the steering wheel. It is more likely than not that the pins were driven in from the top, meaning they will have to be driven out from underneath if the quadrant will allow access. This presumes that tapered pins were used and the pin hole is not blind!
