Marquette Tire Tool Usage
Jugster
First Name: Bob
Last Name: Coiro
Board Member Since: 2009
Post by Jugster » Thu Mar 19, 2026 4:34 pm
I'm the proud owner of this 100-year-old Marquette Tire Tool, which works wonderfully for me when it comes to removing a clincher tire from the rim. Unfortunately, I'm not sure how to use it to put a tire back ON the rim. Is anybody familiar with the procedure?
Last Name: Gregush
Re: Marquette Tire Tool Usage
Post by Mark Gregush » Thu Mar 19, 2026 6:33 pm
use the flat end as a tire iron? Otherwise for removing only.
Post by RajoRacer » Thu Mar 19, 2026 7:32 pm
Somewhere around here, I have an original advertisement for that tire tool as I also own one - I never figured out how to do either task - off or on as the ad shows !
Last Name: Hatch
Post by Dan Hatch » Fri Mar 20, 2026 2:38 pm
troutjohn
Last Name: Trout
* REQUIRED* Type and Year of Model Ts owned: 1923 runabout, 1913 touring
Post by troutjohn » Fri Mar 20, 2026 6:28 pm
Jugster, could you describe how you used it to remove the clincher? Much appreciated.
John
