What have you done with your T in March?
Chris Instness
First Name: Christopher
Last Name: Instness
Post by Chris Instness » Sun Mar 08, 2026 6:49 pm
The weather was perfect for a drive with some speedster friends.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: What have you done with your T in March?
Post by Dan McEachern » Mon Mar 09, 2026 12:30 am
That guy with the hat looks familiar!
Post by DanTreace » Mon Mar 09, 2026 10:58 am
On an recent install of an older rebuilt engine, found that the magneto was intermittent, cleaned mag pickup that had some debris, (known good switch) , but still was intermittent at speed showing only 10-15v (T magneto meter). So decided to “flash” the magneto and see if that would fix.
First time for me to do an in car. Chose the Tom Carnegie method using no compass, but the location of two brass magnet screws peened ends. Those you line up by cranking over to be horizontal in line with each other.
Viewing was impossible due seat height and cocking my neck could not see the upper back of the flywheel! But the iPhone camera could, so lowered it in place inside the hogshead inspection opening and took photos.
Lucky this 26-27 hogshead had a casting nub dead center so used that as point to align the bolt ends.
Then the handy golf cart with 36v of good amps to supply current , made an insulated bolt for the (+) in lieu of the tiny spring tip mag contact as thought best to have good electrical path.
8 quick flashes with the (-) cable done by touching the iron hogshead , then ran the engine.
Wonders, the mag pulled strong at fast idle now and at road speed gets 30v on the meter. Successfully done first time and was easy with the brass screw tip to align the magnets too.
Post by DanTreace » Mon Mar 09, 2026 11:12 am
More photos from the iPhone. Small size so it fit into the narrow end of the hogshead inspection port , used flash to get photos.
Note the brass screw ends and a location mark of the casting nub as a guide to get the peened ends of two magnet screws aligned for the flash.
Made insulated bolt to use as the tiny delicate pickup seem too little of contact for high amperes of the 6 golf cart batteries used to flash. Did feel too the jolt and shutter (hand brake/clutch lever forward) of the flywheel coil ring & magnets made on flashing, assured that adequate juice flowed on instant quick flashes!
abcarswell
First Name: Bruce
Last Name: Carswell
* REQUIRED* Type and Year of Model Ts owned: 1924 Model TT, 1934 Fordor
Post by abcarswell » Mon Mar 09, 2026 7:26 pm
Added door straps to my 24 TT C-Cab. They are referenced in the Parts List but could not find any pictures so manufactured using some leather tools and footman’s loops I purchased several years ago. Looks and works as it should.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Mon Mar 09, 2026 8:13 pm
after some bench tests, got a new gear, a voltage regulator and some paint and bolted on the generator.
Bryant
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Wed Mar 11, 2026 12:02 pm
Got mine fired up and took it for a short ride.
I gots some cleaning to do now 😉
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Wed Mar 11, 2026 12:38 pm
I took my ‘24 touring on a 100-mile round trip to a club meeting this past Sunday. Since then I wire-wheeled and painted new to me windshield stanchions that have been laying on the bench for four months, which is in preparation for getting started on a top kit, which is still in the box since being delivered over two months ago. :oops:
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
Last Name: House
Post by George House » Wed Mar 11, 2026 1:27 pm
Delivered my ‘19 centerdoor to a movie set this morning on Congress Avenue right in front of the capitol. The picture car coordinator wanted something from the 20s so I told him it was a ‘22. :lol: Filming begins tomorrow thru Saturday.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Wed Mar 11, 2026 2:30 pm
Close enough for government work George :lol: :lol:
Jones in Aiken SC
First Name: Gregory
Last Name: Jones
Post by Jones in Aiken SC » Wed Mar 11, 2026 10:12 pm
After much gnashing of teeth, got the top completed on my 1912 Commercial Roadster. And pinstriping on the body and wheels by the great David Piatek of Athens, Georgia.
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Post by tman1913 » Wed Mar 11, 2026 11:14 pm
Just trying to remember what goes where. LOL. Mercury Speedster. Some assembly required.😛
Brent Mize
First Name: Brent
Last Name: Mize
* REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Post by Brent Mize » Thu Mar 12, 2026 7:19 am
I’ve been working on finishing up the upholstery on my late 27 Sport Touring.
I’ve been dreading it, but it wasn’t really too bad.
Just paying attention to details.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Thu Mar 12, 2026 11:01 am
Greg, the top and pinstriping looks great!
I tore into my 1911 engine. So far I have found a crack in the transmission brake drum. I'll pull the engine this weekend and see what else I find.
Keith
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Thu Mar 12, 2026 11:02 am
Keith
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Thu Mar 12, 2026 11:02 am
The 1911 T that I restored came with a Holley H1 carburetor, which Corey Walker refurbished for me. It's a great running carburetor, but it has an elbow that doesn't allow the installation of the usual shutoff elbow that is often installed on later carburetors as a safety feature.
After 3 1/2 years of crawling under the car to turn the fuel on and off at the sediment bowl, I found a small inline brass shutoff valve that I installed yesterday. FINALLY, no more crawling under the car to turn the fuel on and off!
Post by Mark Gregush » Thu Mar 12, 2026 1:29 pm
Bought parts to put Ruckstell together and found replacement hood on Facebook Market place.
Jones in Aiken SC
First Name: Gregory
Last Name: Jones
Post by Jones in Aiken SC » Sat Mar 14, 2026 1:10 pm
Brent-
That is a sharp looking 27 Sport Touring! You don't see many of those.
What green is on the car? Do you happen to have the paint code?
Post by Mark Gregush » Sat Mar 14, 2026 1:20 pm
Just brought home a TT closed cab. Plans are to mount it on my 25. Needs some hammer work, doors are missing (might not worry about that) needs glass too along with the top. Pretty solid has surface rust where someone stripping the paint off and lots of bondo. Needed something to sit on so this should work till I get my cutdown body sorted out. :D
PorkChops
First Name: P
Last Name: Chops
* REQUIRED* Type and Year of Model Ts owned: 1924 Tourer
Post by PorkChops » Sat Mar 14, 2026 3:15 pm
The rot in the front bow of my 24 Tourer finally broke through the front wood by the windshield clamp so needed attention... and on removal of the top, it seems the bends were no better...
I was thrilled to find an amazing craftsman just 30 minutes away who could steam bend ash and replace the wood. Bearing in mind that the metalwork fell apart on dismantling and needed to be made back up - this is pretty stunning work in my view..
And then, with a bit of very welcome sunny, warm, spring-like weather, we managed to re-fit the top. It was never going to go back 100% perfectly but I'm prettty pleased with the end result.
Afrazer
First Name: David
Last Name: Frazer
* REQUIRED* Type and Year of Model Ts owned: 1925 closed cab TT. 1925 factory roadster pickup. 1926 two door sedan
Post by Afrazer » Sat Mar 14, 2026 5:10 pm
Fun day outing giving rides to any willing attendees at a local thrift fest!
1925 closed cab TT
1926 two door sedan
Maineiac
First Name: Michael
Last Name: Whalley
* REQUIRED* Type and Year of Model Ts owned: A 1924 TT project, that started as a stripped chassis.
Post by Maineiac » Sat Mar 14, 2026 8:46 pm
I rebuilt my switch, dry fitted the wood to my second front wheel (and it rattles like a maraca, grr), lastly, I picked up a vintage Walker 3 ton floor jack off marketplace for $40. I figure it'll live with the T, and serve well getting it on and off of its tire saving stands.
You know, once I have tires, lol!
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Sun Mar 15, 2026 10:13 am
With a break in the cold, I went back to work on my electrical problem. I posted in November that I was measuring 3.3 volts at my coil box while the starter was cranking. It was too low to fire the coils. I took inspiration from an article written by Milt Webb where he mentioned measuring voltage drop over each individual electrical component. I did that and retested after correcting each current path issue. Overall, I was able to get up to around 4V at the coils, which is still too low. Then I parked the car for winter.
This week I finally measured voltage drop from a starter mounting screw to the negative battery post. I found 0.7V drop! Not having the engine grounded to the frame was my problem. I had a 19" ground strap that I modified and attached to a starter screw and an unused hole in the frame. These are the results.
Ignition on, starter off 6.3V.
Ignition on, starter cranking 6.1V.
I was extatic with the results. Measuring final voltage was actually difficult. The car started immediately even though the gas valve had been closed the whole time. I had to let the carb run out of gas to get cranking voltage.
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Post by rickd » Sun Mar 15, 2026 2:46 pm
Installed window glass and glass channel on the 25 Touring. The 25 uses nickel plated brass glass channel. Used some original channel and channel from two donor windows to get it looking ok. Also installed the original Trico manual wiper that came on this car. This is a July 1925 car so using the Judging Guidelines that mention nickel plated radiator shell and headlight rims available as an accessory in May 1925.
RGould1910
Last Name: Gould
Post by RGould1910 » Sun Mar 15, 2026 3:16 pm
Looks like Robin Pharis??
Last Name: House
Post by George House » Wed Mar 18, 2026 1:50 pm
I picked up the ‘19 centerdoor (that I assured was a ‘22) from the film promotion in downtown Austin TX last Sunday morning. Had to miss church. I understand the film ‘Peaky Blinders’ is popular in England. I never heard of it but the check $$ was good. The T must’ve been the object of thousands of photos. Even received a case of whiskey :D
Post by TRDxB2 » Thu Mar 19, 2026 1:13 am
Giving an old "Gow Job" a makeover. Its going to take awhile for an nice speedster look.
I bought this and numerous good parts from an estate. Don't know if it was intentional but beat up fenders, spot welded to the fender arms, mixed up nuts & bolts, rusted parts were used. Block is a 1926. Its next in line for a look see what I got. Rear tapered leaf spring will be replaced.
I removed my friend from the original image with an AI App on the internet https://cleanup.pictures/
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Fri Mar 20, 2026 4:18 pm
Gave the old girl a bath today ! ;)
Daisy Mae
First Name: Kurt
Last Name: Andersson
Board Member Since: 2024
Post by Daisy Mae » Fri Mar 20, 2026 4:39 pm
Hoisted the body & dropped the frame today.
She's cleaning up very quickly with just a wire wheel.
10 minutes in on the front crossmember, nice clean unpitted metal.
Could a single D (vs DB) stamp suggest Dodge manufacture??
Vrayfoster
First Name: Victor
Last Name: Foster
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1915 Touring
Board Member Since: 2002
Post by Vrayfoster » Sun Mar 22, 2026 4:12 pm
Restoring my 1910 Touring car
[image][/image]
Post by Dollisdad » Sun Mar 22, 2026 5:02 pm
Mounted the cowl lamps.
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Post by TMiller6 » Sun Mar 22, 2026 5:57 pm
I got my wheels back from the sandblaster-powder coater on Friday. Since it’s raining today I stayed inside to begin mounting my tires. I have no doubt that the late Stan Lee would have agreed with my choice of tire.
Tom Miller
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Mar 23, 2026 6:02 pm
Worked on the floor boards of my wife's speedster.
The cardboard templates show the design of the trim plates a buddy of mine is making.
Keith
First Name: Keith
Last Name: Townsend
Keith
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Mon Mar 23, 2026 9:26 pm
I am rebuilding my 1916 Roadster rear end (July-August 2025 VF Gift Horse). I replaced worn out axles, put in newer non-chipped ring and pinion, modern pineon bearing, set R-P and diff. halves tolerances, and today pulled the rear spring and perch steel bushings. I tapped them with a 5/8-16 tap, removed the tap, heated the bushings with a MAP torch, replaced the tap and pursuaded the bushings out with a 2 1/2 lb hammer! I should have used a 5/8 bolt but this worked well. Waiting for bronze bushings and other parts to arrive.Noel :D
Robert Kiefaber
First Name: Bob
Last Name: Kiefaber
* REQUIRED* Type and Year of Model Ts owned: 1906 model F, 1907 model R, 1915 centerdoor sedan, 1921 centerdoor sedan
Post by Robert Kiefaber » Tue Mar 24, 2026 12:23 am
“Nuff Said”
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Tue Mar 24, 2026 6:20 pm
I spent February repairing some frame and spring issues and putting in new rods, this month have been putting some miles on it to getting ready for a 5 day trip in the Mojave Desert. I have it almost packed and excited to go. Hopefully they are done with the heat wave by the time we get there. We will trailer the cars to Needles California and leave from there, not sure how many will be going but maybe up to 8Ts.
