Valve guide clearence
Flyingpiper59
First Name: Edwin
Last Name: Douglas
* REQUIRED* Type and Year of Model Ts owned: 27 Tudor
Post by Flyingpiper59 » Sat Mar 21, 2026 5:39 pm
Good evening Forum Chums!
It’s been a while since I’ve been on. I got sidetracked from putting my Model T engine back together which I am doing a complete rebuild on!
Unfortunately, there was some illness of a family member that I had to deal with for the last couple of years…….I noticed in the Ford service manual. It says that the maximum allowance between the valve guide wall and the valve is .008 …….frankly that seemed like a huge number to me, but that’s what the manual says. I checked my valve Guide holes with my ball gauge and between the new .312 valves in the guide wall is consistently .004
So my question is actually two fold….. does anyone know what the valve to valve guide clearance was originally? And would you all be having a warm and fuzzy with a .004 valve to valve guide clearance!….. i’ve come this far, but if folks think I should ream it out and go with oversize valves to tighten the clearance even more, I would just love to have y’all’s opinion.
Again, thanks in advance!
Cheers!
big2bird
First Name: Jeffrey
Last Name: Hausey
Re: Valve guide clearence
Post by big2bird » Sat Mar 21, 2026 5:47 pm
I would be okay with .004".
Post by speedytinc » Sat Mar 21, 2026 6:03 pm
Measure the valve stems. The clearance should be built in. they should measure .001-.0015 under .3125.
I go be the wiggle test. I expect .004 will feel excessively loose, in which case I, personally, would knurl & burnish the guides back to .312.
If Ford says .008 or less is ok, Its your call. Its also a matter of your performance & longevity expectations.
Modern motor specs have exhaust max @ .004 & intake @ .003. Expect extra oil burning from the looser intake valves.
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sat Mar 21, 2026 7:59 pm
too often people will go with too little clearance in a rebuild ! .004 clearance is not excessive , and is possibly a result of bell mouthing in the upper and extreme lower portions of the guide ... if .004 is the clearance measured at the extreme wear points ,then it is likely less in the middle area ... too little clearance and the valves will likely stick open ... if .004 is the extreme , then i would go for it and enjoy the car ...
RGould1910
Last Name: Gould
Post by RGould1910 » Sun Mar 22, 2026 10:18 am
You'd be surprised at the amount of lifter guide clearance you can get away with. One time I reamed the guides using a straight flute reamer with the block on a mill. Big mistake. Opened up the guides beyond Fords limit, forget the numbers. I didn't want to open up the bosses and sleeve, so I took a chance and assembled the engine. Car ran fine. It's been in the family for about 25 years. No issues.
