Are the reproduction Exhaust manifolds correct for 14?
Topic author - Posts: 77
- First Name: Bill
- Last Name: Dodd
- * REQUIRED* Type and Year of Model Ts owned: 14 T Touring
I am stockpiling parts for my early 14 touring (late Oct 1913) while the engine is being rebuilt. Is the current reproduction exhaust manifold correct for an early 14 T? I am trying to keep the car as year correct as is easily possible.
14 Touring
Re: Are the reproduction Exhaust manifolds correct for 14?
Until recently the reproductions were 25-27 style. I don't know if a pre-25 style is being made now. I would check with dealers for an original. Most of them carry used parts not listed in their catalogues. Bob's, Chaffin's, Lang's, etc. There are also the used parts specialists like Model T Haven and Ron Paetz (Lone Pine Enterprises).
I like to keep things original where and when possible. That said, assuming you have no other correct manifold that fits, then a repro manifold is really the way to go. It will fit and you will keep from damaging the rear exhaust port on your new engine. The least amount of warp on an original manifold requires the elimination of one or more support glands. The manifold will continue to warp and the ensueing exhaust leak will slowly erode the manifold mating face on the block. If you intend to drive this car much, this is a prudent place to skip originality until you are able to find an excellent original (which will be far and few between).
The repro manifold is one of the best investments in parts you can make...it is a very good product. I have one on each of 4 cars.
- First Name: Bill
- Last Name: Dodd
Thank you
That explanation of the warpage issue makes total sense. This will be another deliberate change, along with rear end thrust bushings, front wish bone and the reason for the engine rebuild, a Scat crank to replace the broken original!
14 Touring
On a previous thread I detailed a most satisfactory way to fit a slightly bent original manifold using an offset gland ring or two. It can be done, it will last and it will allow you to use an original manifold.
I remember that post...why not post a link for him (and us)?
- First Name: R.V.
- Last Name: Anderson
Steve J. is correct; the repros are nice and will fit fine but are the later style. I have several original '14 manifolds and will be happy to part with one to a good home
Scott, if you know how to direct him to my post, feel free to do so. I'm not that clever yet.
Bill
scan down this to see how Allan uses slightly bent manifolds with success: https://www.mtfca.com/phpBB3/viewtopic. ... 961#p47961
- First Name: Bill
- Last Name: Dodd
Thanks for the replys and advice. One thing I forgot to mention (due to a slipping clutch in my brain) is that the rear exhaust port on my block has seen some repair in the past and therefore I will use a new manifold. Don't want to risk any more damage to the block.
14 Touring
