Tar & beans
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Tar & beans
Post by D.Yoder » Wed Feb 05, 2020 11:59 pm
I do not think it will run on TaR & beans😩
I pulled the tank for cleaning tomorrow.
Last Name: Hjortnaes
Re: Tar & beans
Post by DHort » Thu Feb 06, 2020 1:43 am
Needs to be beans and molasses. Throw in some sugar, too.
FreighTer Jim
Last Name: Jarzabek
Board Member Since: 2008
TarBeans
Post by FreighTer Jim » Thu Feb 06, 2020 6:53 am
" Tarbeans " is the nickname of a a small community college athletic program in Alabama ...
I would imagine ....
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
D.Yoder
First Name: DEAN
Last Name: YODER
Re: Tar & beans
Post by D.Yoder » Thu Feb 06, 2020 12:09 pm
Cleaning started :D
StanHowe
First Name: Stan
Last Name: Howe
Re: Tar & beans
Post by StanHowe » Thu Feb 06, 2020 12:59 pm
Plug the openings, put some gravel from the driveway in with some water, lacquer thinner, soap and a handful of rusty old square nuts of various sizes, bungee cord it to the back wheel on your 8N and go for a slow drive for an hour or so. It will knock all the crap loose, the inside will be shiny and at least hopefully be clean enough you can solder it with a torch without worrying about it blowing up. If you are, run the hose from the wife's vacuum cleaner from the exhaust pipe on the 8N to the inside the tank, let it run for awhile before and while you are soldering. She will never know and you won't blow the tank up. =)
Larry e rutt
Last Name: Rutt
* REQUIRED* Type and Year of Model Ts owned: 1926 fordor
Re: Tar & beans
Post by Larry e rutt » Thu Feb 06, 2020 1:22 pm
Here is how I cleaned my tank.. cut the bottom out, cleaned it an welded it back on..[image][/image]
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Re: Tar & beans
Post by Jack Putnam, in Ohio » Thu Feb 06, 2020 1:35 pm
Stan has it. It works every time. A shop vac will remove all the stones when done.
Re: Tar & beans
Post by Scott_Conger » Thu Feb 06, 2020 3:31 pm
Stan/Jack, will it work with a Jubilee, too, or is that too new? :D
StanHowe
First Name: Stan
Last Name: Howe
Re: Tar & beans
Post by StanHowe » Thu Feb 06, 2020 5:05 pm
Too new. Dean has an 8N.
Mark Osterman
Last Name: Osterman
Re: Tar & beans
Post by Mark Osterman » Fri Feb 07, 2020 11:18 am
I plugged both holes with dish detergent solution and a few pounds of bbs. Then rolled it around on the lawn. Flushed it out and removed the bbs followed by an alcohol wash and evaporation dry. Beautiful on the inside. I make sure there is always at least half full with non ethanol gas.
