4 th main bearing cap
Rich Huggins
Topic author - Posts: 107
- First Name: Rich
- Last Name: Huggins
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
Looking for rear 4 th main bearing cap none of the supply shop,s have it who makes this and were can i get one
John M Maslack
- Last Name: Maslack
Re: 4 th main bearing cap
Perhaps Gene French?
Do you mean the part which is on the torque tube of the universal joint? or the inner ball joint part which contains the babbit holding the rear of the transmission?
Or if you are looking for the 3rd or rear main bearing of the engine block? All these parts can be obtained used and usually only need new babbit poured to make them usable.
Rich Huggins
- First Name: Rich
Re: 4 th main bearing Ball cap
The bearing cap that is on the back of supports rear trans clutch and trans assembly Sorry my bad its called a Bearing Ball Cap want one with a bearing and sleeve can not find one anywhere lang,s part #3369bbd
I missed read the need but I will stick by my OP on use of babbitt 4th main.
If you are talking about the ball bearing type, many people do not recommend the use of them and to stick with the original babbitt type.
Joe Bell
- First Name: Joe
- Last Name: Bell
I have an aluminum one that you need to turn the driven plate down for it, I may even have a driven plate turn down for it. If of interest give me a jingle. 419-618-1025
- Last Name: Patrick
Mark, when I sent my rear 4th bearing support to have new babbit poured, I was requested to include the drive plate shaft, so it could be machined and the babbit poured to match the shaft size. Without the shaft, there is no guarantee that it won’t be too loose or too tight. Jim Patrick
Rich Huggins
- First Name: Rich
Rich Huggins
- First Name: Rich
Sorry double post I want ball cap with bearing and seal more support to support auxiliary trans in put shaft
