pressure plate
Rich Huggins
Topic author - Posts: 107
- First Name: Rich
- Last Name: Huggins
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
pressure plate
Took trans cover off to check bands and clutch adjust while looking at the clutch fingers one has a lot of play bad word **** the pin is all the way in and wont come out 1/4 in play don't know but think this is bad it drives fine don't here any thing broken plate tore up clutch disc o no $$$$$ lmao
Rich Huggins
- First Name: Rich
Re: pressure plate
any one have any advice
Re: pressure plate
Can't be driving fine when you are only using two finger on the disk. The ring could be setting at an angle with the disks stuck in grooves in the guides. Or could be broken pin on clutch disk. If the other two are sticking above the drive plate when the collier is pulled back, then there are issues that need to be addressed. You are only using 2/3rds of you ring.
Rich Huggins
- First Name: Rich
Re: pressure plate
i have a pin on clutch plate that is stuck down and the clutch finger has a lot of play can i take out the clutch housing bolts to the brake drum so see the damage i do not have the time to pull the engine out and the rear end
