We are machining a pair of new straight axles and have a couple questions. We have a pair of badly worn originals but would like to verify two things.
1. What width should the key way be? Our original is very worn and wide.
2. What is the relationship of the pin or bolt hole to the keyway? It appears to be roughly 90 degree or has a centerline perpendicular to the centerline of the keyway.
Please private message me or email me at lebsackmike@gmail.com
Straight axle questions
Mike Lebsack-Iowa
Topic author - Posts: 555
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Kerry
- Last Name: van Ekeren
Re: Straight axle questions
maybe of some help, key for the straight axle 1/4x 1/4 x 4-9/16, Bore on the hub 1-1/16 x 4-3/4
Mike Lebsack-Iowa
- First Name: Mike
Thanks Kerry, every little bit helps. Mike
Dan B
- Last Name: Blaydon
