New Top Bows Discussion
GEmering
First Name: Gene
Last Name: Emering
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
Post by GEmering » Mon Sep 07, 2020 10:13 am
I am finishing up the rear end and driveshaft rebuild on the ‘24 Touring and simultaneously and slowly gathering parts for the ‘13 Touring project.
After removing what was left of the well-worn top, I have bows that have seen better days.
I have received a recommendation for new bows from a member here. I also notice that Snyder’s sells a set of 4 for $310 and Lang’s for $99. Not sure why such a big difference in price?
Both state that the ends have to be shaped to fit the irons.
Anyone here use these?
A big deal or easy to shape?
Any chance of finding a good original set?
Other advice?
Thank you MTFCA
Gene
Gene Emering
Newton, New Jersey
DJPeterson
First Name: Dale
Last Name: Peterson
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1916 Roadster, 1925 Roadster PU, 1926 Canadian Fordor, 1927 Speedster
Re: New Top Bows Discussion
Post by DJPeterson » Mon Sep 07, 2020 5:46 pm
The $99 set is most likely the steam bent solid oak. The$310 are likely the laminated bows. They say the laminated are more stable and less prone to the curve straitening.
aDave
First Name: David
Last Name: Dufault
Post by aDave » Mon Sep 07, 2020 6:27 pm
Boy, that's a good question.
I knew Snyder's was expensive...but that's a huge difference. Better check with Lang's to be sure their price is not a typo.
Also, Both Lang's and Snyder's description state steam bent....if Snyder's were laminated, that could be part of the price difference, but the ad does state "steam bent".
Check prices verbally...to be sure.
Good Luck.
Last Name: Seth
Post by perry kete » Mon Sep 07, 2020 6:33 pm
Some fellas use a product called "Quick Polly" if I am correct. It is an epoxy that fills the gaps and makes wood strong again. In past posts they talk about it.
Post by Mark Gregush » Mon Sep 07, 2020 6:42 pm
I would call Snyders and ask to make sure, might be an old description that got over looked and was not updated and are really laminated. The 99$ Langs price is in line with other steam bent bows they sell, then a price jump for laminated.
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Post by Steve Hughes » Tue Sep 08, 2020 9:25 pm
Perry: Quik Poly was a wonderful product for repairing soft or holey wood. Unfortunately it is no longer available. The maker retired and refused to sell the formula and rights to anyone. Gone forever I’m afraid.
