Everbright Protectaclear on Radiator
PAdey
Topic author - Posts: 12
- First Name: PETER
- Last Name: ADEY
- * REQUIRED* Type and Year of Model Ts owned: 1914 Runabout Pickup Conversion
I have read several threads over the years claiming how great the Everbright Protectaclear coating is on brass if the proper preparation is followed. I have not seen feedback on the durability of the product on the radiator. Has anyone tried this coating on their brass radiator? A bit nervous about how it may perform with the heat of the radiator.
SurfCityGene
- First Name: Gene
- Last Name: Carrothers
Re: Everbright Protectaclear on Radiator
Did you check the other thread about brass radiator. Any coating on brass will eventually fail. Professional types will last much longer like on your high $$$$ door knobs.
1912 Torpedo Roadster
James_Lyons-WV
- Last Name: Lyons
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1915 Touring, 1925 Coupe
When I cleared my brass with the product, I contacted the company and found the upper temperature range of the coating to be more than adequate. But I chose to not coat the radiator because I drive my cars and the brass radiators are bound to require work. I didnt want to have to strip the coating so I left the radiator bare.
James_Lyons-WV
- Last Name: Lyons
Here is a link to the thread I wrote almost two years ago on the topic. And the car still looks great!!
http://www.mtfca.com/discus/messages/70 ... 1493474056
