Help ID’ing Body Brackets
richc
First Name: Rich
Last Name: Chillingworth
* REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
Post by richc » Mon Feb 25, 2019 10:42 pm
I need to learn more about Model T bodies! Where do these brackets go, what do they do, and what years were they used? Thank you for your kind help.
Rich C.
dobro1956
First Name: Donnie
Last Name: Brown
Re: Help ID’ing Body Brackets
Post by dobro1956 » Tue Feb 26, 2019 10:10 am
They are touring rear fender irons. 1925 and earlier. I do not remember how early, and Im not home with my books. Maybe someone can give the time period. Yours are the cast style, so they are early "first generation" of that style rear fender iron. The later "second generation" of that part was made as a "stamping" of flat plate. The two styles look alike and function the same. The major difference as to "looks" is the stamped steel version has a "seam" down the top of the round rod part of the bracket where the plate was "rolled" into a round rod.
Post by Rich Eagle » Tue Feb 26, 2019 11:56 am
I'm sure I will be corrected. A parts vendor lists some new ones like that for 1913 to 1917. A later version was rolled from plate rather than cast. Here is a disagreement from 2017.
http://www.mtfca.com/discus/messages/70 ... 1489451603
