front spring perch
Rich Huggins
First Name: Rich
Last Name: Huggins
* REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
front spring perch
Post by Rich Huggins » Fri May 28, 2021 6:29 pm
Hi what is the size of the threads on the pearch shaft that gose through the axel. The head is mushroomed a little and need to clean up with a die, and i need to know what size die i need to buy i think its 5/8 by 20 fine thread but no way of checking
Last Name: Strange
Re: front spring perch
Post by CudaMan » Fri May 28, 2021 6:56 pm
Rich Huggins
First Name: Rich
Last Name: Huggins
Post by Rich Huggins » Sat May 29, 2021 5:46 pm
Thank you for your help and i found a die
