Throttle Rod Question
SurveyKing
Topic author - Posts: 509
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
Happy Independence day weekend to all! I have a question regarding the throttle rod running through the block from the steering wheel to the carb. This is on a 1924 model. There is a distinct bend of about 10 degrees a little less than 2 inches from one end. My question is: Does this end go to the carburetor or the steering column? I am thinking the carb but wanted to try and find out for sure but the service manual does not mention it. Thanks and enjoy your weekend. [/size][/b]
Bill Anziani
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
Re: Throttle Rod Question
The bend goes closest to the steering column
