26 model tt truck seat
jhislop10@gmail.com
First Name: john
Last Name: hislop
* REQUIRED* Type and Year of Model Ts owned: 1926 ford model tt truck
Post by jhislop10@gmail.com » Wed Aug 11, 2021 8:29 pm
help can someone show me a picture of what the support for my truck seat should be. i have the original springs, but all there is to support the springs is the netal frame around the front, but at the back there is just a 1 inch thick by 4 inch wide board that is attached to the cab with 2 hindges.
john
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Re: 26 model tt truck seat
Post by Jeepbone1 » Thu Aug 12, 2021 2:13 am
Is it a closed cab or C cab? Here’s what the closed cab seat frame looks like.
Brad
jhislop10@gmail.com
First Name: john
Last Name: hislop
Post by jhislop10@gmail.com » Thu Aug 12, 2021 9:21 am
great picture thanks
ModelTMark
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
Post by ModelTMark » Fri Aug 13, 2021 10:16 am
There should be wood completely under the seat springs but not attached to the springs. I have a C-Cab and I used plywood. I believe it's hinged so you can lift it up and get to the back storage area.
R/Mark
One390
* REQUIRED* Type and Year of Model Ts owned: 25 TT
Post by One390 » Sat Aug 14, 2021 6:52 pm
If you have the board and hinges- that is bonus, as they seem to be gone most of the time. The board and hinges are for the tool box lid under the seat.
