Brass carburetor bowls
Topic author - Posts: 254
- First Name: Dennis
- Last Name: Fleming
- * REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
I have these two brass bowls and they are 3 inch diameter. The NH bowls are 2 7/8 inch diameter. The one has a 1 inch center hole and the other has a 1/2 inch center hole. I am interested I learning what they fit.
Re: Brass carburetor bowls
My Holley 2 screw is just a hair under 3" and has about an inch hole.
- First Name: Bill
- Last Name: Coyle
The taller bowl looks like the ones on Carter Carbs used on late 20s Chevys. My 28 uses a Carter RAKX-0
- Last Name: Huyett
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T Touring
- Board Member Since: 2013
I could really use the short one for the Holly S for my ‘13 touring. Is it available?
Dan H
Dan H
