1915 tool set
George Mills
Last Name: Mills
1915 tool set
Post by George Mills » Sun Dec 04, 2022 10:48 am
Just posting this as a reference.
Collecting tools is a never ending process. Collecting tools to a year specific compilation is a Don Quixote task also. Here’s my completed ‘1915’ pouch and the like.
Was fun collecting…may need an adjustment or two as time goes on...took over a year. Lots of help and support from a whole bunch of forum guys…Thanks to all
Michael Peternell
First Name: Michael
Last Name: Peternell
Re: 1915 tool set
Post by Michael Peternell » Sun Dec 04, 2022 6:26 pm
I'll take one! Very cool!
Re: 1915 tool set
Post by Steve Jelf » Sun Dec 04, 2022 9:35 pm
The Holy Grail there is the screwdriver. Very few have survived. I consider one of the tools issued with every car suitable for display only. The little Ford tire irons make changing clincher tires the job from Hell. 24" HF irons are inexpensive and provide plenty of leverage. The #1917 band adjusting wrench works, but the 5Z-826 ratchet used in Ford shops is less tedious to use.
Moxie26
Last Name: Jablonski
Re: 1915 tool set
Post by Moxie26 » Sun Dec 04, 2022 9:49 pm
Steve ....I have a 5Z-826 wrench and the ratchet is jammed.. any suggestions to free it up? Thanks in advance.
Re: 1915 tool set
Post by Steve Jelf » Sun Dec 04, 2022 10:23 pm
Clamp an ¹¹⁄₁₆" nut face up in a vise with enough protruding to get the wrench on it. Oil the ratchet generously and work it loose.
Moxie26
Re: 1915 tool set
Post by Moxie26 » Sun Dec 04, 2022 10:43 pm
Thanks Steve
First Name: Austin
Last Name: Farmer
Re: 1915 tool set
Post by 1925 Touring » Wed Dec 07, 2022 10:44 am
Did it work?
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Re: 1915 tool set
Post by Altair » Fri Dec 09, 2022 3:26 pm
Just a question, I have a single chamber FORD tire pump which one is the earlier, the single chamber or the dual chamber?
Re: 1915 tool set
Post by Steve Jelf » Fri Dec 09, 2022 10:30 pm
...I have a single chamber FORD tire pump which one is the earlier, the single chamber or the dual chamber?
Single is later. It's the one you see in the 8-5-28 parts book. I believe they were first brass, then steel. If you have a brass one it should clean up real pretty.
I carry an electric pump in the car, and this as a backup. It works just like it did a hundred years ago. Gives you plenty of exercise.
Altair
First Name: David
Last Name: Menzies
Re: 1915 tool set
Post by Altair » Sat Dec 10, 2022 2:56 am
Thank you for the prompt reply.
