1915 Horn Wiring
Topic author - Posts: 85
- First Name: David
- Last Name: Simmering
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1925 Coupe, 1926 Roadster Pickup
1915 Horn Wiring
We have a 1915 T Roadster with an electric horn. The tube on the steering column is very small diameter and won't admit two wires. The question is, how did Ford wire the horn? Thank you in advance.
- Last Name: van Ekeren
Re: 1915 Horn Wiring
Magneto horn, 2 terminals on horn, 1 power from mag, the other wire runs to the horn button and earth to complete a circuit when button pushed.
- First Name: David
Thank you so much for the help. Now it makes sense. I will scrape some paint off below the switch so as to get a good ground (earth).
