Fat Man missing parts
vping
Topic author - Posts: 251
- First Name: Vincent
- Last Name: Pina
- * REQUIRED* Type and Year of Model Ts owned: 1925 Tudor Sedan
One of the many parts being giving to me with the 25, is a Fan man steering wheels. First thing I noticed is that he lost the screws that hold the wood rim on. Now that I've had a good look at it, the center hub seems to be missing a screw in badge? I also don't know what else is missing to make it function.
- Last Name: Tannehill
- Board Member Since: 2002
Re: Fat Man missing parts
Vincent just regular wood screws will work even better if they were slightly rounded imho. Check the depth of the existing hole’s & diameter for your screws. It appears your steering wheel is set up for a horn. I don’t think it’s a Fatman steering wheel but rather a locking steering wheel in which case you may need a key if it is not already engaged for steering. I’m always a bit hesitant to use those with out the key or a way to disassemble to see what I actually had. This style has ball bearings involved for free wheeling when not engaged. Be careful. Best John
GG Gregory
- First Name: GG
- Last Name: Gregory
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster
It’s going to be tuff finding the right horn button. And, that’s not a Fat Man steering wheel.
vping
- Last Name: Pina
Good to know. I only know what the owner told me which is why I'll be asking a lot of questions!
Thanks.
Vince
Thanks.
Vince
