Outside oil line
Cambin
First Name: Cameron
Last Name: Smythe
* REQUIRED* Type and Year of Model Ts owned: 1925 Duncan and Fraser 1/2 ton pickup and a 1922 Sydney built steenbhoms tourer
Outside oil line
Post by Cambin » Tue Jul 09, 2019 6:29 am
Outside oil line
Cambin
First Name: Cameron
Last Name: Smythe
Re: Outside oil line
Post by Cambin » Tue Jul 09, 2019 6:35 am
I was just finishing putting the last few bits back on my new engine when I discovered that the outside oil line was dodgy so I looked at my other engines oiler and copied it
It is a 1/2” copper fitting a bit of pipe and a plate
And this is how it came out
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Tue Jul 09, 2019 7:54 am
Even if this is what appears to be a right hand drive Starter, rotation is the other way so it would appear your pick up is backwards?
John Warren
Last Name: Warren
Post by John Warren » Tue Jul 09, 2019 8:11 am
Cameron, Nice job I am sure it w ill work great.
Cambin
First Name: Cameron
Last Name: Smythe
Post by Cambin » Tue Jul 09, 2019 8:26 am
Take time to think about that john if I crank an engine clock wize and if you look at the hogshead right the out let of my oil line is end close wize I think it’s the correct way
Cam
Cambin
First Name: Cameron
Last Name: Smythe
Sorry jim
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Tue Jul 09, 2019 9:58 pm
Looks correct, the starter hangs on the left from the drivers seat and rotation throws oil over the top toward the top of starter and the picture shows the starter mount holes for the left forward Side .
