Saw an interesting wrench (spanner) with Ford on it.
Topic author - Posts: 1967
- Last Name: Tannehill
- Board Member Since: 2002
I saw this tool at a friends place, it had the Ford script stamped on the upper part of the handle so i did some research on it. Apparently sometime in 1913-14 time frame Ford used this tool in their service operations. Does anyone have any further documentation on it? Attached is a picture and the only info I could find related to Fords use.
Re: Saw an interesting wrench (spanner) with Ford on it.
Here are a couple of pictures of the actual tool I saw.
Erik Johnson
- First Name: Erik
- Last Name: Johnson
YouTuber Hand Tool Rescue recently reproduced that style of wrench:
https://www.youtube.com/watch?v=ZspDqxx2MFY
John
Interesting for a script on be on a Made in England unusual wrench. Might be a practical tool like a Swiss Knife, doubt it had much application in a Ford shop.
If that script is stamped in, the size is very small, since flourish of the ‘F’ is missing, hard to know if authentic.
For years copies of Ford scripts have been found on many things.
Dan it’s there it’s just warn, tried to get a better picture of but that’s as good as the phone would do.
Cruby
- First Name: Carl
- Last Name: Ruby
- * REQUIRED* Type and Year of Model Ts owned: None
Some tools with Ford stamped on them were for plant use, so they stayed in the plant.
