1915 Runabout Side Curtain Drawings
mortier
First Name: Philip
Last Name: Jamison
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Post by mortier » Sat Jan 03, 2026 9:23 am
I contacted the Benson Ford Library looking for the 1915 Runabout Side Curtain drawings, and the librarian said they need the correct part numbers. The parts list they referred me to has many that seem to fit the bill. Could anyone tell me what part numbers I should request?
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: 1915 Runabout Side Curtain Drawings
Post by Humblej » Sat Jan 03, 2026 12:55 pm
As per the Ford Parts Price List dated 1916.
Side Curtin Rear R.H. 6937X
Side Curtin Rear L.H. 6938X
Side Curtin Front R.H. 6935X
Side Curtin Front L.H. 6936X
You can see the Manuals, parts lists, etc. at Cimorelli Model T on line.
mortier
First Name: Philip
Last Name: Jamison
Post by mortier » Sat Jan 03, 2026 3:20 pm
Thanks for your help. My car is missing some of the fasteners, and I thought the plans might show where they were.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sat Jan 03, 2026 3:46 pm
Phillip,
For 1915 the only fasteners are the common sense fasteners on the bows and the body. There are no windshield fasteners for 1915.
I believe the post-1919 side through 1922 sidecurtains with windshield hooks would work if you install side curtain hooks.
Keith
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sat Jan 03, 2026 7:35 pm
For 1915 through at least the 1918 model year, there are two straps at the front of the side curtain to keep it snug at the windshield - one strap goes between the windshield and hinge and the other goes around the sidelamp.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sat Jan 03, 2026 9:38 pm
Yes, straps on the side curtain only. No fasteners on the windshield.
Cars equipped with starter motors did not have sidelamps so the engineers had to come up with a way to attach the side curtains... so side curtain hook on the windshield were introduced.
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Mon Jan 05, 2026 10:22 am
The issue with those numbers is those will only be Assembly Drawings. It likely will have the part numbers to all of the sub-assemblies that make-up the piece however it has been my experience the dimensions will not be included in those drawings. You will need each piece to accurately reproduce the entire curtain.
