Block and head test plate and gasket
Les Schubert
Topic author - Posts: 1364
- First Name: Les
- Last Name: Schubert
I am putting together a order to make a run of;
1. 1/2” thick aluminum test plates that facilitate leak testing the T block and heads prior to assembly (or prior to doing ANY work). They will run about $150.00
2. Neoprene reuseable head gasgets for the same testing process. About $50.00
modeltbarn
- First Name: Gary
- Last Name: London
Chad_Marcheese
- First Name: Chad
- Last Name: Marcheese
- * REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1923 Speedster Gow Job
Re: Block and head test plate and gasket
I have an interest in it. I can't fully commit yet, but let me know as you get closer to needing a finalized list or payment.
Les Schubert
- First Name: Les
Chad
Well I hope to finalize this week!!
Erik Barrett
- First Name: Erik
- Last Name: Barrett
Put me down for one.
pre15dale
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Las, Put me down for one also. Dale
Les Schubert
- First Name: Les
Dale
I have added one plate and two gaskets for you
Others, this project is now finished and closed off!!
