Motor knock
Haroldc30
First Name: Harold
Last Name: Chambers
MTFCA Number: 50278
Motor knock
Post by Haroldc30 » Wed Sep 18, 2019 7:42 pm
I have a 25 t about 35 mph when the motor is running free I have a clapping sound when I give it gas the noises goes away when motor is holding back no noise. I have plastic gauge rods and mains they r within spec. Could it possible be a pistol slap? it has .040 over I put new pistons and rings in it.I have drove it several thousand miles sense then it's no worse or better. that noise is driving me nuts. Thanks in advance Harold.
philip
First Name: Philip
Last Name: Thompson
Re: Motor knock
Post by philip » Wed Sep 18, 2019 8:39 pm
Mind tends to make that sound when I have the spark too advanced. My chapter
Bought one of the solid-state coil testers we put new capps. And points in the coils and set them.
Now I don't need as much advance. Philip
FrankHarris
Last Name: Harris
Re: Motor knock
Post by FrankHarris » Thu Sep 19, 2019 4:19 am
Some times the connecting rods can get twisted and will cause a knock. We had a 1913 that had that issue. Straightened the rods and the knock went away.
John Dow
Last Name: Dow
MTFCA Number: 32344
MTFCI Number: 24459
Re: Motor knock
Post by John Dow » Thu Sep 19, 2019 11:26 am
Harold, Do you by chance have an aluminum high compression head? I do and I had a very similar loud knock as you described. It drove me crazy trying to find the cause. It turned out to be pre-ignition engine knock. I found by running 91 octane and using a little less advance the noise went away.
Haroldc30
First Name: Harold
Last Name: Chambers
MTFCA Number: 50278
Re: Motor knock
Post by Haroldc30 » Thu Sep 19, 2019 1:25 pm
Don't have high compression head but have high compression pistons.I will try what you did.Thanks
John Dow
Last Name: Dow
MTFCA Number: 32344
MTFCI Number: 24459
Re: Motor knock
Post by John Dow » Thu Sep 19, 2019 1:52 pm
Harold, I bet you have the same problem! Hopefully, you can solve it as I did. Please follow up and let us know the result.
