is an almost touching clearance of the comutator terminal ( #4 cylinder) to the high speed clutch finger when engaged normal on the NRS. Mine seems like it could hit if there is any movement in the engine/transmission assembly. This is closest at top dead center. Shimming between engine and transmission would give more clearance.
thanks Jim
NRS Comutator clearance of clutch fingers
JvanMaanen
Topic author - Posts: 197
- First Name: Jim
- Last Name: Van Maanen
- * REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
Re: NRS Comutator clearance of clutch fingers
Is the terminal bolt maybe a bit too long? Protruding from the thumb nut more than necessary?
JvanMaanen
- First Name: Jim
Thanks Jerry, the bolts are all the same length and don't protrude from the thumb screws. Of course, I have no idea if the bolts or thumb screws are original. I will double check the timing and also check the thumb screws against those on my 15. there has to be some way I can get a little more clearance.
