Offering my 1915 Ford Model T roadster #874180. I found another car, so need space! This T is an older restoration. Though not perfect, it looks pretty good. No rust or damage. I’m not sure what the late owner did mechanically, but it starts right up, runs smooth and drives. Radiator has no leaks. Tires and wheels are good and run straight. Here is what I have done to the car:
- Coils rebuilt and tested by The Coil Doctor
- Carburetor rebuilt by Randy Potter
- Block & radiator flushed
- New fan belt
- New radiator hoses & tube (water pump included)
- New fuel line & safety valve
- New brass sediment bowl
- New lined brake shoes & cams
- New floor mat
- 12 & 6 volt batteries under the seat
- New drain plug
- Wheel bearings cleaned & packed
- New rear axle stubs
- Fresh engine & diff. oil
- New plug wires and wiring harness.
- New transmission oil screen & gaskets
Engine starts nicely on coils and runs well on mag. (often giving a “free” start). Steers straight; tubes hold air. Upholstery and top look good; windshield good. New Day timer works well. The easy-change transmission bands appear to have cotton linings, and look OK.
For more photos: https://link.shutterfly.com/jGKdHZnnGLb
Good PA title. Contact me for more photos. Located in West Chester, PA.
$11,500
610-696-8449
1915 Model T Roadster
Topic author - Posts: 102
- First Name: Philip
- Last Name: Jamison
- * REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Re: 1915 Model T Roadster
Hershey delivery possible on this car!
-- SOLD --
