1924 Cutoff Touring Pickup
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
Post by KBurket » Fri Dec 05, 2025 1:05 pm
1924 Cutoff Touring Pickup. $6000 OBO.
Engine serial number is August 1923.
Low hours on rebuilt motor.
Only ran on property a few times giving rides to family and friends.
Last run around 2010.
New body woodwork using Mel Miller’s drawings.
Professional paint.
Respoked wheels. 21” split rims.
Rebuilt rear end and new lined brake shoes.
Includes rear fenders and mounting hardware.
KBurket
First Name: K
Last Name: Burket
Re: 1924 Cutoff Touring Pickup
Post by KBurket » Fri Dec 05, 2025 1:08 pm
Rebuilt motor and transmission.
Engine number 8782xxx.
New wiring harnesses.
Gas tank clean and dry.
KBurket
First Name: K
Last Name: Burket
Post by KBurket » Fri Dec 05, 2025 1:11 pm
Includes bracket to hold speedometer and partial speedometer included.
Pickup as found early 2000’s.
KBurket
First Name: K
Last Name: Burket
Post by KBurket » Fri Dec 05, 2025 1:24 pm
Powder coated bed hardware.
New wood for bed included.
Receipts show:
Frame, axles, oil pan, and original hardware for wood pickup bed powder coated 2004/05. Kitsap Powder Coating LLC.
New Rootlieb hood 2007.
New seat springs and upholstery kit installed 2007.
Ron Patterson Rebuilt coils in rebuilt coil box with lid. 2006.
Motor and transmission rebuilt 2004-2006.
X-Act Machine Services,Bothell WA.
Reground cam, new 0.030 pistons, modern valves, valve guides, inside oil line, rebabbitted rods and mains.
Rebuilt transmission 2004.
New triple gear pins and bushings. Bead blast and magniflux drums, install new bushing set. Clean, reinstall, and recharge magnets. Coil ring gap set with KRW gap gauge.
Engine work reciepts from Steve’s T Works, Milton WA. 2006.
Rebuilt Holly NH Carb, rebuilt coil box, Anderson timer, rebuilt steering bracket, new wire harnesses, copper head gasket, new head bolts, +.
West Seattle Radiator Works.
Recored high radiator and new radiator neck. 2004.
Located north of Poulsbo, WA on the Kitsap Peninsula.
Sold with bill of sale.
Posted for a neighbor.
Send me an email through the forum for more information.
KBurket
First Name: K
Last Name: Burket
Post by KBurket » Tue Feb 10, 2026 1:10 pm
Motivated seller wants to clear out garage.
Make an offer!
