MODEL T PARTS COLLECTION , CHEAP
Chaffins
Topic author - Posts: 334
- First Name: Herbert
- Last Name: Chaffin
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1911 touring, 1913 roadster, 1914 touring
THIS A 60 YEAR COLLECTION OF MODEL T FORD PARTS. THERE IS NO JUNK PARTS, THEY ARE ALL GOOD USEABLE PARTS. THIS IS A GIVE AWAY PRICE.
PRICES SHOWN ARE FAIR MARKET VALUE, THIS IS WHAT YOU CAN SELL THE PARTS FOR.
ASKING PRICE IS LESS THAN 0.060 CENTS ON THE DOLLAR
BUYER MUST BUY ENTIRE COLLECTION TO GET THESE PRICES
YOU WON’T FIND ANY LOWER PRICES
MODEL T FORD PARTS COLLECTION
OVER THE YEARS WE HAVE SOLD OVER $50,000.00 WORTH OF INDIVIDUAL PARTS FROM THIS COLLECTION WITHOUT ADVERTISING. AND LOOK AT WHAT WE STILL HAVE. AT THIS POINT IN MY LIFE I MUST LIQUIDATE WHAT IS LEFT AT A SUPER LOW PRICE. WE RE SELLING INDIVIDUAL PARTS CHEAP , BUT IF YOU WANT THEM REALLY CHEAP BUY THE ENTIRE COLLECTION.
MOTORS AND BLOCKS FAIR MARKET VALUE
1915 BLOCK 800.00
1916 ENGINE 1,000.00
WITH LOW HEAD AND EARLY PAN
1916 ENGINE 800.00
1916 BLOCK 300.00
1916 BLOCK 300.00
1916 BLOCK 300.00
1916 BLOCK 300.00
1919 BLOCK 100.00
1919 BLOCK 100.00
1920 SHORT BLOCK 150.00
1920 BLOCK 100.00
1920 BLOCK 100.00
1920 BLOCK 100.00
1921 BLOCK 100.00
1922 BLOCK 100.00
1922 BLOCK 100.00
1922 BLOCK 100.00
1922 BLOCK 100.00
1923 BLOCK 100.00
1923 BLOCK 100.00
1924 BLOCK 100.00
1924 BLOCK 100.00
1925 BLOCK WITH CRANK 150.00
1925 BLOCK 100.00
1925 BLOCK 100.00
1925 BLOCK 100.00
1926-27 ENGINE 800.00
1926-27 BLOCK 500.00
TOTAL $8,120.00
MOTOR PARTS FAIR MARKET VALUE TOTAL
8 FMC VALVES 3.00 24.00
4 ALUMINUM PISTONS AND300.00 300.00
RODS, GOOD BABBITT
4 ALUMINUM PISTONS AND RODS, USED 100.00 100.00
47 CAST IRON PISTONS 5.00 235.00
30 LIGHT RODS 20.00 600.00
66 HEAVY RODS 5.00 330.00
151 ROD CAPS 5.00 755.00
472 ROD BOLTS 2.00 944.00
150 ROD CLAMP BOLTS 1.00 150.00
2 LOW HEADS 125.00 250.00
ONE IS GOOD, THE OTHER NEEDS TO BE SURFACED
23 HEADS 50.00 1,150.00
40 LOW HEAD BOLTS 2.00 80.00
195 HIGH HEAD BOLTS 2.00 390.00
32 DOMED HEAD BOLTS 2.00 64.00
201 SPARK PLUGS 1.00 201.00
37 CRANKS 50.00 1,850.00
33 CRANK GEARS 10.00 330.00
56 FRONT MAIN CAPS 10.00 560.00
17 CENTER MAIN CAPS 10.00 170.00
43 REAR MAIN CAPS 10.00 430.00
206 FRONT AND CENTER 2.00 412.00
MAIN BEARING BOLTS
82 REAR MAIN BEARING BOLTS 2.00 164.00
2 TIMING COVERS (16-19) 50.00 100.00
17 TIMING COVERS (20-25) 25.00 425.00
17 TIMING COVERS (26-27) 25.00 425.00
26 LATE VALVE COVERS 20.00 520.00
11 EARLY CRANK PULLEYS 25.00 275.00
54 LATE CRANK PULLEYS 15.00 810.00
6 FLANGED CRANK PULLEYS 20.00 120.00
16 CRANK PULLEY PINS 1.00 120.00
2 13-15 PANS 250.00 500.00
5 1916-25 PANS 50.00 250.00
9 1926-27 PANS 150.00 1,350.00
14 3 DIP LOWER PAN COVERS 35.00 470.00
AND HORSE SHOES
13 4 DIP LOWER PAN COVERS 50.00 650.00
AND HORSE SHOES
10 SETS PAN HORSE SHOES 20.00 200.00
8 PAIR 26-27 OIL PAN 45.00 337.50
CORNER BRACKETS
10 EARLY CRANK PULLEYS 20.00 200.00
53 LATE CRANK PULLEYS 15.00 795.00
6 ACCESSORY FLANGED 30.00 180.00
CRANK PULLEYS
3 OIL CAPS 20.00 60.00
35 EARLY INTERNAL OIL LINES 10.00 350.00
5 LATE INTERNAL OIL LINES 10.00 50.00
6 EARLY BRASS HUB FANS 75.00 450.00
8 1916-20 FANS 35.00 280.00
9 1921-24 FANS 35.00 315.00
1 1926-27 FAN 35.00 35.00
18 FAN BLADES 5.00 90.00
10 1916-25 FAN HUBS 8.00 80.00
9 1926-27 FAN HUBS 15.00 135.00
18 FAN ARMS 5.00 90.00
60 FAN SHAFTS 5.00 300.00
14 FAN MOUNTING BOLTS 2.00 28.00
2 1916-21 CRANK HANDLES 25.00 50.00
10 1921-27 CRANK HANDLES 25.00 250.00
23 CRANK RATCHETS 25.00 575.00
300 OILERS 0.50 150.00
40 OIL COCKS 1.00 40.00
10 OIL PAN RADIUS ROD CAPS 3.00 30.00
10 ACCESSORY RADIUS ROD CAPS 3.00 30.00
17 CAMSHAFTS 10.00 170.00
37 CAMSHAFTS 20.00 740.00
190 CAM GEAR NUTS 3.00 570.00
55 CAM GEARS 10.00 550.00
43 TIMER CAM NUTS 1.00 43.00
20 TIMER PINS 1.00 20.00
22 1909-25 CAM BEARINGS 5.00 110.00
12 1926-27 CAM BEARINGS 5.00 60.00
13 CENTER CAM BEARINGS 5.00 65.00
42 CAM BEARING SPRINGS 2.00 84.00
82 VALVES 1.00 82.00
43 LIFTERS 1.00 43.00
234 VALVE SPRING SEATS 0.50 121.50
225 VALVE SPRINGS 0.50 112.50
12 FOURTH MAIN BEARINGS 20.00 240.00
13 SIDE WATER FITTINGS 10.00 130.00
6 EARLY FRONT WATER FITTINGS 10.00 60.00
17 FRONT WATER FITTINGS 10.00 170.00
18 WATER PUMPS 50.00 900.00
4 WATER PUMP PULLYS 10.00 40.00
1 WATER PUMP SHAFT 10.00 10.00
TOTAL $25,264.50
STARTERS
12 STARTERS 50.00 $600.00
STARTER PARTS
13 FIELD ASSEMBLIES 10.00 130.00
4 FRONT SUPPORT HOUSINGS 5.00 20.00
9 REAR BRUSH COVERS 5.00 45.00
10 BRUSH HOLDERS 5.00 50.00
16 STARTER SPRINGS 3.00 48.00
15 REAR COVERS 3.00 45.00
TOTAL $338.00
STARTER SWITCH
6 STARTER SWITCH AND EXTENSIONS 2.00 12.00
TOTAL $12.00
BENDIX & PARTS
56 BENDIX 50.00 2,800.00
16 BENDIX SPRINGS 1.00 16.00
17 BENDIX DRIVE HEADS 5.00 85.00
14 BENDIX SLEEVE ENDS 3.00 42.00
15 BENDIX COVERS 10.00 150.00
TOTAL $3,093.00
GENERATORS
34 GENERATORS 50.00 1,700.00
TOTAL $4,900.00
GENERATOR PARTS
25 FIELD ASSEMBLIES 10.00 250.00
2 ARMATURES 10.00 20.00
17 BRUSH HOLDERS AND PARTS 5.00 85.00
78 SEAL WASHERS 0.50 39.00
18 BRUSH HOLDER LOCK RINGS 2.00 36.00
5 FRONT COVERS 5.00 25.00
72 GEARS 4.00 288.00
20 BEARINGS 1.00 20.00
15 REAR COVERS 2.00 30.00
TOTAL $793.00
FANS
10 1916-20 FANS 35.00 350.00
10 1926-27 FAN HUBS 15.00 150.00
10 1916-25 FAN BLADES 8.00 80.00
26 FAN ARMS 5.00 130.00
76 FAN SHAFTS 5.00 380.00
1 FANARM, PULLEY & SHAFT 10.00 10.00
TOTAL $2,098.00
MANIFOLD AND EXHAUST
84 INTAKEC MANIFOLDS 5.00 420.00
16 EXHAUST MANIFOLDS 10.00 160.00
14 EXHAUST PACK NUTS 5.00 70.00
21 EARLY MANIFOLD CLAMPS 8.00 168.00
5 EXHAUST PIPES 10.00 50.00
28 HOT AIR PIPES 5.00 140.00
8 26-27 MANIFOLD CLAMP BOLTS 3.00 24.00
2 MANIFOLF CLAMP BOLTS 1.00 2.00
2 CUTOUT PEDALS 5.00 10.00
TOTAL $1044.00
TRANSMISSIONS
3 EARLY TRANSMISSIONS 300.00 900.00
7 LATE TRANSMISSIONS 300.00 2,100.00
1 26-27 TRANSMISSION 300.00 300.00
TOTAL 3,300.00
TRANSMISSION PARTS
20 FLYWHEEL 50.00 1,000.00
16 FLYWHEEL WITH MAGNETS 75.00 1,200.00
306 MAGNETS 5.00 1,530.00
79 MAGNITO COILS 25.00 1,975.00
1 MAGNITO COIL SHIM 2.00 2.00
108 MAGNET SUPPORT BOLTS 1.00 108.00
78 FLYWHEEL BOLTS 1.50 117.00
25 FLYWHEEL PINS 1.00 25.00
300 MAGNET KEEPERS 1.00 300.00
2,400 CLUTCH DISC’S 1.00 300.00
300 BRASS SCREWS .50 150.00
100 TRANS. THRUST WASHERS 1.00 100.00
18 CLUTCH FINGERS 2.00 36.00
60 MAIN SHAFT 35.00 2,100.00
28 REVERSE DRUM 100.00 2,800.00
20 LOW DRUM 100.00 2,000.00
20 EARLY BRAKE DRUM 100.00 2,00.00
3 LATE BRAKE DRUM 100.00 300.00
18 DRIVE GEAR 20.00 360.00
50 DRIVE GEAR KEYS 1.00 50.00
55 1909-25 CLUTCH DRIVE PLATES 50.00 3,000.00
22 1926-27 CLUTCH DRIVE PLATES 50.00 1,100.00
171 DRIVE PLATE BOLTS 1.00 171.00
94 TRIPLE GEARS 40.00 3,760.00
73 CLUTCH DRUMS 30.00 2,190.00
54 CLUTCH THROWOUT COLLARS 20.00 1,080.00
58 CLUTCH SPRINGS 5.00 290.00
58 CLUTCH SPRING CUPS 5.00 290.00
7 BRASS CLUTCH CLEVIS 10.00 70.00
27 PEDAL CAMS 1.00 27.00
13 LOW PEDAL CAMS 1.00 13.00
15 1916-25 BRAKE PEDALS 10.00 150.00
11 1926-27 BRAKE PEDALS 10.00 10.00
29 REVERSE PEDALS 10.00 290.00
3 LOW SPEED PEDALS 10.00 30.00
18 LOW SPEED ADJUSTMENT SCREWS 5.00 85.00
30 PEDAL NUTS 1.00 30.00
38 DEMOUNTABLE BANDS 25.00 950.00
93 NON DEMOUNTABLE BANDS 5.00 465.00
15 LOW SPEED ADJUSTMENT SHAFTS 2.00 30.00
12 LOW SPEED CLEVIS LINKAGE 5.00 60.00
28 PEDEL SPRINGS .50 14.00
10 PEDAL SHAFTS 1.00 10.00
TOTAL $30,368.00
TRANSMISSION COVERS
2 ALUMINUM TRANSMISSION COVERS 125.00 250.00
8 16-19 TRANSMISSION COVERS 50.00 500.00
7 20-25 TRANSMISSION COVERS 50.00 350.00
5 TRANSMISSION COVER PLATES, FLAT 15.00 75.00
41 TRANSMISSION COVER 10.00 410.00
PLATES (16-27)
7 MAGNITO POSTS 1909-15 8.00 56.00
28 MAGNITO POST 8.00 224.00
11 MAGNITO POST 8.00 88.00
20 MAGNITO POST OILERS 1912-25 10.00 200.00
11 MAGNITO POST OILERS 1926-27 10.00 110.00
2 FORD FAITHFUL TYPE OILERS 20.00 40.00
3 TRANS COVER OILERS 10.00 30.00
4 OIL SCREENS 10.00 40.00
TOTAL $2,373.00
MUFFLERS
1 CAST IRON MUFFLER 25.00 25.00
1 STEEL MUFFLER 20.00 20.00
1 CAST END WITH TAIL PIPE 25.00 25.00
1 PAIR CAST IRON ENDS 15.00 15.00
1 PAIR STEEL ENDS 10.00 10.00
18 MUFFLER SHELLS 2.00 36.00
TOTAL $131.00
CARBURETORS & PARTS
14 HOLLY G CARBURETORS 40.00 560.00
8 L2 KINGSTON CARBURETORS 35.00 280.00
15 L4 KINGSTON CARBURETORS 35.00 525.00
41 HOLLY NH CARBURETORS 50.00 2,050.00
5 VAPORIZER CARBURETORS 40.00 200.00
1 VAPORIZER INTAKE 5.00 5.00
35 CARBURETOR BOWLS 5.00 175.00
37 CARBURETOR FLOATS 3.00 110.00
11 NEEDLES 5.00 55.00
7 CHOKES 5.00 35.00
25 BOTTOM NUTS 3.00 75.00
3 DASH CHOKE SWIVELS 5.00 15.00
6 CARBURETOR CONTROL RODS 6.00 36.00
52 CARBURETOR CONTROL RODS 5.00 260.00
TOTAL $4,381.00
FRAME
2 FRAMES 125.00 250.00
TOTAL $250.00
FRAME PARTS
5 FRONT CROSSMEMBERS 25.00 250.00
3 REAR CROSSMEMBERS 25.00 150.00
2 1909-21 FRONT MOTOR MOUNTS 35.00 70.00
8 1922-24 FRONT MOTOR MOUNTS 35.00 280.00
15 1925-27 FRONT MOTOR MOUNTS 35.00 525.00
3 LOW FIREWALL 50.00 150.00
1 HIGH FIREWALL 50.00 50.00
1.5 PAIR 1911-15 FIREWALL 75.00 112.50
MOUNTING BRACKETS
6 PAIR 1916-19 FIREWALL 25.00 150.00
MOUNTING BRACKETS
13 PAIR 1920-25 FIREWALL 25.00 325.00
MOUNTING BRACKETS
2 BATTERY CABLE SUPPPORTS 5.00 10.00
1 BATTERY BOX 25.00 25.00
1 HAND BRAKE CROSS SHAFT 10.00 10.00
TOTAL $ 2,107.50
GAS TANK
11 SETS 1913-22 GAS TANK MTG. BKTS. 25.00 275.00
10.5 SETS 1923-27 GAS TANK MTG. BKTS 25.00 262.50
9 GAS CAPS 5.00 45.00
42 GAS LINE SEDIMENT BULBS 10.00 420.00
SOME BRASS
3 26-27 GAS LINE SEDIMENT BULBS 10.00 30.00
1 GAS LINE FILTER 5.00 5.00
TOTAL $1,037.50
FRONT AXLE
1 1911-19 FRONT AXLE WITH PERCHES 150.00 150.00
5 1920-27 FRONT AXLE WITH PERCHES 200.00 1,000.00
SPRINGS AND SPINDLES
3 1920-27 FRONT AXLES WITH PERCHES 140.00 420.00
AND SPINDLES
1 1920-27 FRONT AXLE WITH SPINDLES 120.00 120.00
5 FRONT AXLES WITH PERCHES 120.00 500.00
16 1920-27 FRONT AXLES WITH NO 50.00 800.00
SPINDLES OR PERCHES
1 1909-12 FRONT SPRING PERCH 20.00 20.00
8 1913-15 SPRING PERCH 20.00 160.00
29 1916-21 SPRING PERCH 10.00 290.00
68 1922-27 SPRING PERCH 10.00 680.00
5 DRAG LINKS 35.00 175.00
38 TIE RODS 25.00 950.00
1 EARLY WISH BONE 25.00 25.00
18 WISHBONES 25.00 450.00
26 SPINDLE ARMS 10.00 260.00
59 FRONT SPINDLES 20.00 1,180.00
27 SPINDLE BOLTS 2.00 54.00
110 TIE ROD BOLTS .50 110.50
21 TIE ROD CAPS 5.00 105.00
7 RADIUS ROD CAPS 5.00 35.00
10 TIE ROD BALLS 5.00 50.00
2 RADIUS ROD ENDS 8.00 16.00
45 FRONT INNER BEARINGS 5.00 225.00
31 FRONT OUTER BEARINGS 5.00 155.00
25 FRONT HUB NUT 2.00 50.00
TOTAL 7,980.00
SPRINGS
12 FRONT SPRINGS 100.00 1,200.00
79 FRONT SPRING LEAVES 5.00 395.00
5 TAPER LEAF SPRING LEAVES 10.00 50.00
8 REAR SPRINGS 100.00 800.00
31 REAR SPRING LEAVES 5.00 155.00
1.5 FRONT SPRING CLAMPS 8.00 12.00
1 REAR SPRING CLAMP SET 8.00 8.00
TOTAL $2,620.00
DRIVE SHAFTS
3 DRIVE SHAFT ASSEMBLIES 100.00 300.00
11 DRIVE SHAFTS 50.00 550.00
2 SHORT DRIVE SHAFT TUBES 25.00 50.00
9 EARLY DRIVE SHAFT TUBES 75.00 675.00
2 LATE DRIVE SHAFT TUBES 25.00 50.00
5 DRIVE SHAFT BALL ASSEMBLIES 5.00 25.00
12 DRIVE SHAFT BALL COLLARS 5.00 60.00
19 U-JOINT, GOOD 50.00 1,250.00
10 U-JOINTS, BAD 5.00 50.00
10 DRIVE SHAFT SLEEVES 5.00 50.00
5 EARLY DRIVE SHAFT SPOOL RACES 5.00 25.00
24 EARLY DRIVE SHAFT THRUST WASHERS 10.00 240.00
20 LATE DRIVE SHAFT THRUST BEARINGS 10.00 200.00
5 DRIVE SHAFT SPOOLS 10.00 50.00
23 DRIVE SHAFT THRUST BEARING ASSY 10.00 230.00
6 DRIVE SHAFT THRUST BEARINGS 8.00 48.00
9 DRIVE SHAFT SPOOL BEARINGS 10.00 50.00
89 DRIVE SHAFT SPOOL STUDS AND NUTS 1.00 89.00
25 DRIVE SHAFT SPOOL BOLTS 1.00 25.00
33 PAIR RADIUS RODS 75.00 2,475.00
10 MISC RADIUS RODS NEED WORK 5.00 50.00
30 RADIUS ROD SUPPORT BRACKETS 2.00 60.00
186 RADIUS ROD BO0LTS 1.00 186.00
50 DRIVE SHAFT LARGE OILERS 4.00 200.00
TOTAL $6,938.00
REAR AXLE ASSEMBLIES
4 1916-22 REAR AXLE ASSEMBLIES WITH 400.00 1,600.00
DRIVE SHAFT
6 1916-22 REAR AXLE ASSEMBLIS WITH 300.00 1,800.00
OUT DRIVE SHAFTS
2 1926-27 REAR AXLE ASSEMBLIES WITH 400.00 800.00
DRIVE SHAFTS
1 1926-27 DRIVE SHAFT ASSEMBLY WITH 300.00 300.00
OUT DRIVE SHAFT
TOTAL $4,500.00
REAR AXLE PARTS
1 DIFFERENTIAL ASSEMBLY WITH AXLES 250.00 250.00
1 DIFFERENTIAL ASSEMBLY WITH AXLES 325.00 325.00
AND RING GEAR
25 REAR AXLE HOUSINGS 10.00 250.00
35 AXLES WITH GEARS 75.00 2,625.00
30 AXLES, NO GEARS 50.00 1,500.00
25 AXLE GEARS 25.00 625.00
31 DIFFERENTIAL ASSEMBLIES, GOOD 100.00 3,100.00
46 DIFFERENTIAL ASSEMBLIES, 20.00 920.00
NEED REPAIR
10 SMALL HALF, DIFFERENTIAL 50.00 500.00
55 DIFFERENTIAL SPIDERS AND GEARS 50.00 2,750.00
33 SPIDERS, NO GEARS 20.00 660.00
38 RING GEARS 75.00 2,850.00
4 11 TOOTH PINIONS 75.00 300.00
2 10 TOOTH PINIONS 100.00 200.00
40 26-27 BRAKE BACKING PLATES 5.00 200.00
30 PAIR REAR SPRING U-BOLTS 35.00 1,050.00
4 PAIR 1909-25 CAST IRON BRAKE SHOES 5.00 20.00
9 PAIR 1909-25 ACCESSORY LINED 10.00 90.00
BRAKE SHOES
6 1926-27 BRAKE DRUMS 25.00 150.00
2 1926-27 BRAKE DRUMS WITH HUBS 50.00 100.00
3.5 PAIR 26-27 BRAKE SHOES 35.00 122.50
40 1909-25 BRAKE DRUMS 25.00 1,000.00
14 SNUBBER SPRINGS 1.00 14.00
2 MODERN AXLE BEARINGS 20.00 40.00
84 AXLE BEARINGS 5.00 420.00
5 AXLE SLEEVES 1.00 5.00
50 BRAKE PIVOT BOLTS 1.00 50.00
27 LONG DIFFERENTIAL BOLTS 1.00 27.00
80 LONG DIFFERENTIAL STUDS AND NUTS 1.00 80.00
300 OUTER HOUSING BOLTS 1.00 300.00
60 DIFFERENTIAL HOUSING PLUGS 1.00 20.00
300 DIFFERENTIAL STEEL WASHERS 1.00 300.00
73 EARLY REAR AXLE SPRING HANGERS 8.00 584.00
11 LATE REAR AXLE SPRING HANGERS 8.00 88.00
125 EARLY BRAKE CAM ARMS 8.00 1000.00
26 LATE BRAKE CAM ARMS 8.00 208.00
22 PAIR 1916-25 RADIUS RODS 25.00 550.00
3 PAIR 26-27 RADIUS RODS 25.00 75.00
2 SHORT RADIUS ROD SETS 25.00 50.00
6 BRAKE ROD SETS, NEED REPAIR 5.00 30.00
25 1916-25 BRAKE ROD SETS 10.00 250.00
1 SHORT BRAKE ROD SET 10.00 10.00
4 1926-27 BRAKE ROD SETS 10.00 40.00
5 BREAK ROD CLEVIS 5.00 25.00
2 BRAKE ROD SUPPORT SETS 8.00 16.00
1 OUTER SEAL SET, ALUMINUM 10.00 10.00
10 LARGE OILERS 3.00 30.00
37 MEDIUM OILERS 1.00 37.00
225 SMALL OILERS 1.00 225.00
92 ZIRK FITTINGS 1.00 92.00
96 TWIST OILERS 1.00 96.00
TOTAL $24,289.50
SHACKLES
1 PAIR 1909-12 FRONT SHACKLES 20.00 20.00
1 PAIR 1909-12 REAR SHACKLES 20.00 20.00
8 PAIR 1913-17 FRONT SHACKLES 20.00 160.00
8 PAIR 1913-17 REAR SHACKLES 20.00 160.00
70 PAIR 1917-22 FRONT SHACKLES 10.00 700.00
30 PAIR 1917-22C REAR SHACKLES 10.00 300.00
74 PAIR 1922-27 FRONT SHACKLES 10.00 740.00
41 PAIR 1922-27 REAR SHACKLES 10.00 410.00
31 PAIR 1922-27 SPRING SHACKLES, REPAIR 5.00 155.00
68 EARLY SHACKLE OILERS, BRASS 3.00 204.00
TOTAL $2,869.00
WHEELS
4 30X3 ROUND FELLOW WHEELS, NO HUBS 25.00 100.00
2 30X3 SQUARE FELLOW WHEELS WITH HUBS 35.00 70.00
2 30X3 SQUARE FELLOW WHEELS, NO HUBS 25.00 50.00
2 30X3.5 SQUARE FELLOW WHEELS, NO HUBS 25.00 50.00
2 30X3.5 DEMOUNTABLE WHEELS, 25.00 50.00
GOOD WOOD
12 30X3 NON DEMOUNTABLE RIMS 25.00 300.00
8 30X3.5 NON DEMOUNTABLE WHEEL RIM 25.00 200.00
5 30X3.5 DEMOUNTABLE RIM 5.00 25.00
3 30X3.5 RIM LUGS 5.00 15.00
4 30X3.5 DEMOUNTABLE RIMS, GOOD 25.00 100.00
2 21 INCH SPLIT RIMS 25.00 50.00
54 FRONT HUBS 25.00 1,350.00
12 STAR AND MISC HUB CAPS 2.00 24.00
41 REAR HUBS 25.00 1,025.00
6 REAR AXLE CAPS 1.00 6.00
26 HUB BACKING PLATES 5.00 130.00
3 WHEEL PULLERS 25.00 75.00
68 WIRE WHEEL HUB NUTS 1.00 68.00
15 WIREWHEEL HUB GREASE SEALS 5.00 75.00
10 WIRE WHEEL HUB OIL SEALS 2.00 20.00
70 HUB CAPS 2.00 140.00
3 TRUCK HUB CAPS 3.00 9.00
24 TRUCK RIM LUGS 2.00 48.00
39 METAL STEM TUBE VALVES AND COVERS 1.00 39.00
30 FRONT WHEEL HUB COVER PLATES 5.00 150.00
3 PLATES FOR WOOD FELLOW WHEELS 5.00 15.00
1 SPARE TIRE CARRIER 50.00 50.00
6 SPARE TIRE CARRIER ARMS 10.00 60.00
5 SPARE TIRE BRACKETS 5.00 25.00
1 21 INCH RIM SPREADER 45.00 45.00
45 OUTER FRONT BEARINGS AND RACES 5.00 225.00
31 INNER FRONT BEARINGS AND RACES 5.00 155.00
TOTAL $4,794.00
BODY, FENDERS, RUNNING BOARDS AND HOODS
2 HIGH FIREWALKL 50.00 100.00
5 PAIR DOOR WINDOW ESCUSSION PLATES 10.00 50.00
1 PAIR CLOSED CAR BODY SILL PLATES 10.00 10.00
1 SET WOOD PICKUP BOX IRONS 25.00 25.00
2 PAIR 1923-25 REAR TOURING FENDER IRONS 25.00 50.00
2 PAIR 1914-22 REAR TOURING FENDER IRONS 45.00 90.00
MISC BODY BRACKETS AND IRONS 50.00 50.00
1 1919-22 ROADSTER AND TOURING DASH 35.00 35.00
12 FRONT LICENCE BRACKETS 5.00 60.00
1 1914 DOOR LOCK 50.00 50.00
5 1916-22 DOOR LOCKS 20.00 100.00
10 1923-25 DOOR LOCKS 20.00 200.00
3 MISC DOOR LOCKS 10.00 30.00
6 DOOR LOCK SPRINGS 1.00 6.00
35 STRIKER PLATES 5.00 175.00
1 CLOSED CAR DOOR HANDLE 10.00 10.00
1 STIRRUP HANDLE 10.00 10.00
1 ROBE RAIL 50.00 50.00
13 MISC RODS AND CLEVISES 20.00 20.00
1 SET 1911 HOOD CLAMPS 25.00 25.00
16 SETS 1916-27 HOOD CLAMPS 10.00 160.00
2 SETS EARLY RUNNNG BOARD BRACKETS 50.00 100.00
20 FENDER MOUNTING BRACKETS ON FENDERS 5.00 100.00
3 FOOT THROTTLE CONTROL BRACKETS 10.00 30.00
11 FRONT BODY BRACKETS 10.00 110.00
27 DOOR HINGES 10.00 270.00
2 1923-25 CLOSED CAR DOORS 75.00 150.00
1 PAIR HOOD HANDLES 10.00 10.00
8 PAIR 1916-22 HOOD SHELVES 10.00 80.00
2 PAIR 1926-27 HOOD SHELVES 10.00 20.00
3 BODY PATCH PANELS 5.00 15.00
13 HAND BRAKE RATCHETS 3.00 39.00
2 EARLY HAND BRAKE PLATES 5.00 10.00
1 LATE HAND BRAKE PLATE 5.00 5.00
20 BODY BRACKETS 1.00 20.00
30 CLEVIS PINS .50 15.00
2 CLOSED CAR DOORS 100.00 200.00
6 TOURING REAR DOORS 25.00 150.00
3 LOW COWLS 25.00 75.00
2 SEAT PANS 10.00 20.00
3 DASH 10.00 30.00
3 UPHOLSTERY END CAPS 5.00 15.00
TOTAL $2,920.00
HOODS
2 LOW HOOD SIDES 30.00 30.00
8 PAIR 1916-22 HOOD SHELOVES 10.00 80.00
1 SET 1911 HOOD HOOKS 25.00 25.00
20 SETS 1916-27 HOOD HOOKS 10.00 200.00
TOTAL $365.00
RADIATORS
1 BRASS RADIATOR 100.00 100.00
1 LOW RADIATOR 50.00 50.00
108 BRASS PETCOCKS 2.00 216.00
42 MODEL T BRASS PETCOCKS 2.00 84.00
70 MISC ODD OIL COCKS 1.00 70.00
1 LOW RADIATOR SHELL 50.00 50.00
1 RADIATOR TOP FITTING 5.00 5.00
1 RADIATOR CAP 10.00 10.00
TOTAL $585.00
BODY AND LIGHT BRACKETS
3.5 SETS 1911-15 PEDAL PLATES 25.00 87.50
9 SETS 1916-22 PEDAL PLATES 10.00 90.00
6 SETS 1926-27 PEDAL PLATES 10.00 60.00
1 SET 1913-14 SIDE LIGHT BRACKETS 45.00 45.00
3.5 SETS 1916-22 CLOSED CAR SIDE 30.00 105.00
LIGHT BRACKETS
7 PAIR ROADSTER FENDER IRONS 150.00 1,050.00
5 TOURING REAR TAILLIGHT AND 45.00 225.00
LICENCE BRACKETS
3 ROADSTER TAILLIGHT AND LICENCE BRACKETS 45.00 135.00
2 TAILLIGHT BRACKETS 25.00 50.00
1 PAIR 1911-14 HEADLIGHT MOUNTING FORKS 75.00 75.00
1 PAIR NON FORD HEADLIGHTFORKS 50.00 50.00
5 PAIR REAR L IRONS 25.00 125.00
1 1926-27 TAILLAMP SUPPORT ARM 15.00 15.00
1 TAILLAMP SUPPORT BRACKET 10.00 10.00
1 TAILLAMP AND LICENCE BRACKET 10.00 10.00
1 FENDER MOUNTING BRACKET 5.00 5.00
2 BATTERY HOLDER BRACKETS 5.00 10.00
TOTAL $2,148.50
STEERING
11 STEERING COLUMNS 200.00 2,200.00
12 STEERING SHAFTS 50.00 600.00
1 WOOD STEERING WHEEL 25.00 25.00
5 1916-25 STEERONG WHEELS WITH SPIDERS 75.00 375.00
1 1916-25 STEERING WHEEL RIM 25.00 25.00
2 IRON STEERING WHEEL SPIDERS 25.00 50.00
5 FORMED STEERING WHEEL SPIDERS 10.00 50.00
4 STEERING COLUMN SUPPORT BRACKETS 10.00 40.00
1 THROTTLE ARM 5.00 5.00
1 SPARK ARM 5.00 5.00
1 EARLY STEERING SUPPORT ARM 10.00 10.00
MISC. STEERING COLUMN HARDWARE 10.00 10.00
11 STEERING WHEEL NUTS 3.00 33.00
5 1915-17 STEERING COLUMN 25.00 125.00
TO FRAME BRACKETS
3 1917-25 STEERING COLUMN 25.00 76.00
TO FRAME BRACKETS
2 1926-27 STEERING COLUMN 25.00 50.00
TO FRAME BRACKET
14 TRUCK STEERING COLUMN 25.00 350.00
TO FRAME BRACKETS
9 PITMAN ARMS 20.00 180.00
26 STEERING BRACKET MOUNTING BOLTS 3.00 78.00
11 SETS 4/1 GEARS 25.00 275.00
3 SETS 4/1 STERRING PINION GEARS 10.00 30.00
2 SET 5/1 STEERING GEARS 25.00 50.00
7 SETS 5/1 STEERING PINION GEARS 10.00 70.00
5 STEERING GEAR BOXES 10.00 50.00
7 TOP COVERS 10.00 70.00
14 STEERING QUADRANTS 5.00 70.00
TOTAL $4,902.00
TOP
27 TOP SOCKET ARMS, VARIOUS YEARS 5.00 135.00
1 PAIR 23-25 TOP REST SUPPORT BRACKETS 20.00 20.00
1 PAIR TOP REAT ARMS AND SADDLES 25.00 25.00
13 TOP PROP NUTS 1.00 13.00
14 TOP STRAP HOOKS AND BUCKLES 5.00 70.00
3 TOP SADDLE SETS 25.00 75.00
2 PAIR REAR TOP LEATHER AND HARDWARE 10.00 20.00
5 MISC TOP IRON BRACKETS 10.00 50.00
2 PAIR 1916-22 FRONT TOP IRON BRACKETS 25.00 50.00
7.5 PAIR 1923-25 FRONT TOP IRON BRACKETS 25.00 187.50
2 PAIR 1916-22 ROADSTER FRONT 25.00 50.00
TOP IRON BRACKETS
8.5 PAIR 1923-25 TOURINJG REAR 25.00 212.50
TOP IRON BRACKETS
2.5 PAIR 1913-15 FRONT TOURING 25.00 62.50
TOP MOUNTING BRACKETS
1.5 PAIR REAR TOURING TOP 25.00 37.50
MOUNTING BRACKETS
1 PAIR 1916-22 ROADSTER REAR 25.00 25.00
17 1916-22 TOURING FRONT TOP 25.00 425.00
MOUNTING BRACKETS
6 1916-22 TOURING REAR TOP 25.00 150.00
MOUNTING BRACKETS
30 FOOTMAN LOOPS 5.00 150.00
6 PAIR FIGURE 8 & TOP HOOKS 5.00 30.00
TOTAL $1,788.00
WINDSHIELD
1 1915 WINDSHIELD 150.00 150.00
3 1913-14 WINDSHIELD HALF FRAMES 25.00 75.00
7 1916-22 WINDSHIELD HALF FRAMES 25.00 175.00
5 1923-25 WINDSHIELD HALF FRAMES 25.00 125.00
MISC WINDSHIELD PARTS 30.00
TOTAL $555.00
SPEEDOMETER AND HORN
1 SPEEDO PARTS 5.00
12 HORN BRACKETS 5.00 60.00
7 HORN PARTS 10.00 70.00
18 HORN BUTTONS AND PARTS 5.00 90.00
TOTAL $225.00
HEADLIGHTS, TAILIGHTS, SPOT LIGHTS AND MIRRORS
15 PAIR 1916-25 HEADLIGHTS 75.00 1,125.00
1 PAIR 1916-25 HEADLIGHTS WITH SEAL BEAMS 75.00 75.00
3 BRASS HEADLIGHT RIMS 10.00 30.00
1 CHROME HEADLIGHT RIM 10.00 10.00
10 HEADLIGHT GLASS LENS 10.00 100.00
17 REFLECTORS 5.00 85.00
MISC HEADLIGHT BULBS 7.00
12 DASHLIGHTS AND PARTS 3.00 54.00
5 RED REFLECTORS 3.00 15.00
8 STOPLIGHT SWITCHES 1.00 8.00
7 HEADLIGHT SWITCHES 1.00 7.00
1 STOP LIGHT 25.00 25.00
2 STOPLIGHT BEZELS AND FRAMES 10.00 20.00
1 BOX OF SIDELAMP. TAILLIGHT AND LENSES 25.00 25.00
2 SPOTLIGHTS 25.00 50.00
3 SPOTLIGHT PARTS 10.00 30.00
1 MIRROR 5.00 5.00
TOTAL $1,671.00
SIDE AND TAILIGHT PARTS
6 TOP 3.00 18.00
5 CHIMNEYS 3.00 15.00
3 CHIMNEY HOUSINGS 3.00 9.00
10 REFRLECTORS 5.00 50.00
10 MAIN BODIES 8.00 80.00
8 DOORS 10.00 80.00
2 GLASS 10.00 20.00
3 BURNERS 5.00 15.00
2 BOTTOMS 8.00 16.00
TOTAL $303.00
IGNITION
2 MASTER VIBRATOR COILS 10.00 20.00
24 COILS 5.00 120.00
1 BOX OF COIL PARTS, NUTS AND BOLTS 10.00 10.00
66 TIMER ROLLERS 4.00 264.00
25 EARLY TIMER ROLLERS 5.00 125.00
6B TIMER NUTS 1.00 6.00
33 TIMERS 5.00 165.00
31 TIMER SHIELDS 1.00 31.00
6 TIMER SPRINGS 1.00 6.00
14 EARLY TIMER SPRING BOLOTS 1.00 14.00
4 LATE TIMER SPRING BOLTS 1.00 4.00
13 DISTRIBUTORS 25.00 325.00
6 DISTRIBUTOR SHAFTS 5.00 30.00
3 DISTRIBUTOR COILS 5.00 15.00
1 BOX OF DISTRIBUTOR SHAFTS, 25.00 25.00
GEARS AND POINTS
7 DISTRIBUTOR HEADS 1.00 7.00
5 SETS DISTRIBUTOR GEARS AND NUTS 10.00 50.00
2 DISTRIBUTOR ROTORS 3.00 6.00
1 1914 COIL BOX 35.00 35.00
7 1915-19 COIL BOX 25.00 175.00
18 1919-25 COIL BOXES 10.00 180.00
2 1919-25 COIL BOX LIDS 10.00 20.00
1 FORDSON COIL BOX 10.00 10.00
9 1926-27 COIL BOXES 10.00 90.00
1 1926-27 COIL BOX LID 20.00 20.00
4 COILBOX WOOD 5.00 20.00
14 IGNITION SWITCH PLATE 1.00 5.00
5 1926-27 IGNITION SWITCH PLATES AND PARTS 5.00 25.00
1 1919 IGNITION SWITCH 10.00 10.00
1 ACCESSORY IGNITION SWITCH 10.00 10.00
BOX OF IGNITION SWITCH PARTS 20.00 20.00
1 AMPMETER MOUNTING BRACKET 5.00 5.00
1 BOX OF ORIGINAL WIRING LOOMS 5.00 5.00
5 WIRE TERMINAL BLOCKS 10.00 50.00
30 WIRING CLAMPS 1.00 30.00
1 BOX OF 40 HEADLIGHT AND TAILLIGHT 25.00 25.00
SOCKETS AND HARDWARE
TOTAL $2,398 .00
TRUCK RUCKSTELL
BOX OF TRUCK RUCKSTELL PARTS, NO HOUSING 100.00 $100.00
MODEL A AND V8
7 MODEL A BENDIX 10.00 70.00
19 MODEL A AND EARLY V8 FRONT HUBS 10.00 190.00
12 MODEL A AND EARLY V8 REAR HUBS AND 10.00 120.00
BRAKE DRUMS
5 MODEL A AND EARLY V8 REAR BRAKE DRUMS 5.00 25.00
1 MODEL A HORN 45.00 45.00
2 MODEL A SHIFTER ARMS 10.00 20.00
1 FRONT SPINDLE 10.00 10.00
1 FAN 10.00 10.00
1 MODEL A WIRE WHEEL 25.00 25.00
1 MODEL A TRANSMISSION SHIFT LEVER 10.00 10.00
3 EARLY V8 WIRE WHEELS 25.00 75.00
1 EARLY V8 TIRE CARRIER 50.00 50.00
2 MODEL A TAILLIGHT SUPPORT ARMS 25.00 50.00
TOTAL $700.00
MISC. PARTS
18 SHELVING UNITS 25.00 450.00
2 HEAVY DUTY RACKS 50.00 100.00
2 TRUCK REAR SPRINGS 25.00 25.00
2 TIRE PUMP WOOD HANDLES 5.00 10.00
7 PAIR HASSLER SHOCKS AND MISC PARTS 50.00
3 PAIR ACCESSORY REAR SPRING HANGERS 10.00 30.00
TOTAL $565.00
GRAND TOTAL, FAIR MARKET VALUE $160,052.50
ASKING $ 10,000.00
10,000.00
169,492.50 = 0.60 CENTS ON THE DOLLAR
THAT’S JUST 6 CENTS ON THE DOLLAR
LOW HEADS $125.00/$7.20
STARTERS AND GENERATORS $50.00/$3.00
GOOD TRANSMISSION DRUMS $100.0/$6.00
1916 ENGINE, WITH LOW HEAD AND EARLY PAN $1,000.00/$60.00
1926-27 ENGINE, $800.00/$48.00
WE WILL SELL THE LOT FOR 0.060 CENTS ON THE DOLLAR BUT YOU MUST BUY IT ALL. YOU WILL NEED A LARGE TRUCK TO MOVE IT.
1915 BLOCK 800.00
1916 ENGINE 800.00
1916 BLOCK 300.00
1916 BLOCK 300.00
1916 BLOCK 300.00
1916 BLOCK 300.00
1919 BLOCK 100.00
1919 BLOCK 100.00
1920 BLOCK 100.00
1920 BLOCK 100.00
1920 BLOCK 100.00
1921 BLOCK 100.00
1922 BLOCK 100.00
1922 BLOCK 100.00
1922 BLOCK 100.00
1922 BLOCK 100.00
1923 BLOCK 100.00
1923 BLOCK 100.00
1924 BLOCK 100.00
1924 BLOCK 100.00
1925 BLOCK 100.00
1925 BLOCK 100.00
1925 BLOCK 100.00
TOTAL $8,120.00
RODS, GOOD BABBITT
MAIN BEARING BOLTS
AND HORSE SHOES
AND HORSE SHOES
CORNER BRACKETS
CRANK PULLEYS
TOTAL $25,264.50
STARTERS
STARTER PARTS
TOTAL $338.00
STARTER SWITCH
TOTAL $12.00
BENDIX & PARTS
TOTAL $3,093.00
GENERATORS
TOTAL $4,900.00
GENERATOR PARTS
TOTAL $793.00
FANS
TOTAL $2,098.00
TOTAL $1044.00
TRANSMISSIONS
TOTAL 3,300.00
TRANSMISSION PARTS
TOTAL $30,368.00
TRANSMISSION COVERS
PLATES (16-27)
TOTAL $2,373.00
MUFFLERS
TOTAL $131.00
CARBURETORS & PARTS
7 CHOKES 5.00 35.00
TOTAL $4,381.00
FRAME
TOTAL $250.00
FRAME PARTS
MOUNTING BRACKETS
MOUNTING BRACKETS
MOUNTING BRACKETS
TOTAL $ 2,107.50
GAS TANK
SOME BRASS
TOTAL $1,037.50
FRONT AXLE
AND SPINDLES
SPINDLES OR PERCHES
TOTAL 7,980.00
SPRINGS
TOTAL $2,620.00
DRIVE SHAFTS
TOTAL $6,938.00
DRIVE SHAFT
OUT DRIVE SHAFTS
DRIVE SHAFTS
OUT DRIVE SHAFT
TOTAL $4,500.00
REAR AXLE PARTS
AND RING GEAR
NEED REPAIR
BRAKE SHOES
TOTAL $24,289.50
SHACKLES
TOTAL $2,869.00
WHEELS
GOOD WOOD
TOTAL $4,794.00
3 DASH 10.00 30.00
TOTAL $2,920.00
HOODS
TOTAL $365.00
RADIATORS
TOTAL $585.00
LIGHT BRACKETS
LICENCE BRACKETS
TOTAL $2,148.50
STEERING
TO FRAME BRACKETS
TO FRAME BRACKETS
TO FRAME BRACKET
TO FRAME BRACKETS
TOTAL $4,902.00
TOP
TOP IRON BRACKETS
TOP IRON BRACKETS
MOUNTING BRACKETS
MOUNTING BRACKETS
MOUNTING BRACKETS
TOTAL $1,788.00
WINDSHIELD
TOTAL $555.00
1 SPEEDO PARTS 5.00
TOTAL $225.00
1 MIRROR 5.00 5.00
TOTAL $1,671.00
6 TOP 3.00 18.00
8 DOORS 10.00 80.00
2 GLASS 10.00 20.00
TOTAL $303.00
IGNITION
GEARS AND POINTS
TOTAL $2,398 .00
TRUCK RUCKSTELL
MODEL A AND V8
BRAKE DRUMS
1 FAN 10.00 10.00
TOTAL $700.00
MISC. PARTS
TOTAL $565.00
ASKING $ 10,000.00
10,000.00
- Attachments
- MODEL T PARTS COLLECTION - COLLECTION.docx
- (54.75 KiB) Downloaded 215 times
Mark Chaffin
Re: MODEL T PARTS COLLECTION , CHEAP
Here is the phone number to call if interested. Glen (951) 735-4791
Chaffins
CORRECTION, TOTAL FAIR MARKET VALUE $160,052.50
Chaffins
SELLING INDIVIDUAL PARTS AT A RAPID SPEED AT FAIR MRKET VALUE. YOU CAN MAKE THE PROFIT. JUST BUY THE LOT AT 0.060/DOLLAR AND RESEL FOR A BIG PROFIT.
Chaffins
RETURN TO TOP
Chaffins
CORRECTION: TOTAL VALUE$160,052.50, SELL FOR $10,000.00, 0.060 SIX CENTS ON THE DOLLAR
Texasroadkill
- First Name: Clint
- Last Name: Bitterly
- * REQUIRED* Type and Year of Model Ts owned: 1923 pickup
- Board Member Since: 2012
Do you still have any foot throttles parts or assemblies left?
big2bird
- First Name: Jeffrey
- Last Name: Hausey
Call me Glen. Jeff Hausey
GarJen127
- First Name: Garrett
- Last Name: J
- * REQUIRED* Type and Year of Model Ts owned: None
Would you sell just the 1916 Engine for $800?
Mark Chaffin
Correct phone number is (951) 735-4791. Ask for Glen
big2bird
- Last Name: Hausey
Thank you Mark
