Two-piece driveshaft fs. Richmond reminder. Sold sold
CTLeonard
Last Name: Leonard
Post by CTLeonard » Fri May 24, 2024 4:16 pm
Actually the whole rear end. Two-piece driveshaft, forged end radius rods, 13 -14 rear end,, Chicago duplex cantilever spring assiste. Richmond is coming, I'm in mt.vernon Indiana. Come load your truck. 800.00 for driveshaft alone. If you take it all( minus wheels) the price is 1250.00. ctleonard64@gmail.com
CTLeonard
Last Name: Leonard
Re: Two-piece driveshaft fs. Richmond reminder
Post by CTLeonard » Fri May 31, 2024 1:43 pm
Come down to mt.vernon Indiana and visit. Have alot of A parts and flathead v8 engines
CTLeonard
Last Name: Leonard
Post by CTLeonard » Sun Aug 04, 2024 2:04 pm
Still for sale
Wayne Mims
First Name: Ervin
Last Name: Mims
* REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
Post by Wayne Mims » Sun Aug 04, 2024 4:13 pm
Has the rear end? Been rebuilt or 1200 the price for a non-rebuilt rear end. Move to top
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Sun Aug 04, 2024 5:46 pm
2 piece drive shaft complete, closed pinion housing, early radius rods & aftermarket accessory rear springs on top of factory taper leaf springs. It appears that there are Hyatt bearings, axles & so forth if you buy the full meal deal. Could be but I doubt it that the rear axle is rebuilt for that price.
CTLeonard
Last Name: Leonard
Post by CTLeonard » Mon Aug 05, 2024 8:23 am
The rear end has not been rebuilt, but it did come out of a running driving car.
1913Runabout
First Name: Brian
Last Name: Harlamoff
* REQUIRED* Type and Year of Model Ts owned: 1913 Runabout, 1922 speedster
Post by 1913Runabout » Mon Aug 05, 2024 11:32 am
Can you post a closeup photo of the spool at the front of the rear end? (between the torque tube and the rear end)
CTLeonard
Last Name: Leonard
Post by CTLeonard » Mon Aug 05, 2024 12:37 pm
Couple of pictures
Last Name: Hatch
Post by Dan Hatch » Mon Aug 05, 2024 12:53 pm
2PC driveshaft tubes use to bring almost what the price is for whole unit.
Post by JTT3 » Mon Aug 05, 2024 8:51 pm
I agree Dan
RGould1910
Last Name: Gould
Post by RGould1910 » Tue Aug 06, 2024 11:18 am
Not around here. At least not in the past 20 yesrs. Top going rate for a 2 pc ds was $800. Now a bit less. Example: the cost of a very nice 1913 rear end complete with 2 pc ds and forged radius rods $800 two years ago.
The one advertised looks good and has the early no hump spool. Id be interested to see if the ujoint ball ring has the raised boss for the grease cup.
CTLeonard
Last Name: Leonard
Post by CTLeonard » Tue Aug 06, 2024 11:53 am
Pictures of the ball ring
RGould1910
Last Name: Gould
Post by RGould1910 » Tue Aug 06, 2024 2:44 pm
Looking closer, it appears the spool is a transition between the two styles we usually see,
consistent with the 13 axle housings. The ring may be the later version. 2 piece driveshafts are hard to find when you need them.
CTLeonard
Last Name: Leonard
Post by CTLeonard » Wed Aug 14, 2024 8:05 am
Xxxxxxxxxx
CTLeonard
Last Name: Leonard
Post by CTLeonard » Thu Aug 29, 2024 8:25 am
Another round
CTLeonard
Last Name: Leonard
Post by CTLeonard » Wed Sep 18, 2024 3:36 pm
Still have the girl, and a front end to match
CTLeonard
Last Name: Leonard
Post by CTLeonard » Mon Oct 14, 2024 11:04 am
Getting harder to find these
CTLeonard
Last Name: Leonard
Post by CTLeonard » Mon Dec 30, 2024 1:47 pm
This has been around awhile, throwing it back out there. Spring is coming! ctleonard64@gmail.com
CTLeonard
Last Name: Leonard
Post by CTLeonard » Mon Mar 17, 2025 8:29 am
Spring is finally coming! Someone surely has a need for these, along with a front end to boot. Email me at ctleonard64@gmail.com
Post by Allan » Mon Mar 17, 2025 9:45 am
I think the first photo after the phone screenshots does show the humps around the bearing spool at the back, so it suits the rest of the parts.
CTLeonard
Last Name: Leonard
Post by CTLeonard » Thu Apr 17, 2025 9:01 am
She is still in the barn. Came out of a running, driving car. ctleonard64@gmail.com
Last Name: Hatch
Post by Dan Hatch » Thu Apr 17, 2025 9:07 am
Someone was looking for the springs while back. I posted a link to this, but guess he didn’t want them bad enough.
CTLeonard
Last Name: Leonard
Post by CTLeonard » Wed May 21, 2025 1:44 pm
One of these days I'll post this and someone will be thrilled to the gods to have finally found one! Is today the day? ctleonard64@gmail.com
RGould1910
Last Name: Gould
Post by RGould1910 » Fri May 23, 2025 10:56 am
Agreed. When you need once, they're impossible to find. After you find one, the market becomes flooded. Same with no "made in usa" heads, cast end radius rods etc.
CTLeonard
Last Name: Leonard
Post by CTLeonard » Tue Jun 10, 2025 11:42 am
I know people are tired of seeing this old post. Someone needs this! In mt.vernon Indiana. Have a front end also. ctleonard64@gmail.com
MikeG
Last Name: Ghormley
Post by MikeG » Fri Aug 08, 2025 11:43 am
OK, I can't stand thinking about this anymore... I'll take it! :) Thanks, MikeG
CTLeonard
Last Name: Leonard
Post by CTLeonard » Fri Aug 08, 2025 12:04 pm
Met Mike and his wife last week , good folks. Seeing the rear end got the best of him , he called when he got home . The rear end finally sold. Thank you mtfca and you mike
