jamlip
- Last Name: Lipman
Post
by jamlip » Fri Jul 05, 2024 9:59 pm
E-Timer, light use, $400.
Used on my car for a couple of years. Works beautifully. Can mail.
James
Tel: 310.Twenty-Two.Seven.Sixty-5.Twenty-5
RVA23T
- Last Name: C
Post
by RVA23T » Fri Jul 05, 2024 10:36 pm
Whoever purchases this unit, there is a 0.05” Spacer Shim that you may or may not need when installing the Vane Actuator Assembly (Replaces Roller) on the cam. It is not shown in the picture.
Is it still on the car James???
Bruce Compton
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post
by Bruce Compton » Sat Jul 06, 2024 3:07 pm
James, I'm interested. Does it have the spacer mentioned and the wiring diagram with it? Bruce
