model A crankshaft into T block bearing mold
Topic author - Posts: 1036
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
i have built 3 of my design mainbearing molds used to pour babbitt for the installation of modified model A Ford crankshaft ( or SCAT configured ) crankshaft into a model T Ford motor block ...these tools are built on demand only since the demand is low ( sold 1 on ebay request) ... they pour the main at 1 1/2" diameter to allow for finish machining of journal diameter and allow for thrust on the block and rear cap ( you machine .04"-.06" off each side of the iron thrust surface of the block to allow for babbitt thrust )... instructions are included as well as my email or phone support ... price is $175.00 plus $18.10 flat rate postage in lower 48 states , actual postage outside this area or INTERNATIONAL ...Gene French 970-581-2808 or gfrench1953@hotmail.com
- First Name: Gene
- Last Name: French
Re: A crabkshaft into T block bearing mold
sorry, PELL checker did not catch "crabkshaft"... didn't catch "pell" either ...
- Last Name: C
I read Crabcakes, man I wish I was in Baltimore!!Gene_French wrote: ↑Sun Aug 18, 2024 12:17 pmsorry, PELL checker did not catch "crabkshaft"... didn't catch "pell" either ...
