Looking for a parking brake arm for the hand brake shaft for my 26.
Topic author - Posts: 573
- First Name: Morgan
- Last Name: Blanchard
I am looking for a good parking brake arm (the one opposite the hand brake lever) for my 26. I have attached a couple of pictures of what I am after. The large hole is 3/4 inch dia. and it is held on by one pin. If you have one in good shape you would be willing to part with (particularly with holes that are round) please send me a pm.
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Re: Looking for a parking brake arm for the hand brake shaft for my 26.
I've got the whole assemblys if that helps?
Karl,
I will keep that in mind.
- First Name: Walt
- Last Name: Wise
You may want to check out the below listing on Ebay. I "think" it includes the part you are looking for and probably another that you aren't?
https://www.ebay.com/itm/256642815117?_ ... R8Cm6uPDZA
No connection to the ad whatsoever...just trying to help...
The auction ENDS in about 7 hours and no bid yet...
- First Name: Austin
- Last Name: Farmer
Bob's Antique Auto parts in Rockford carries lots of old oroginal parts, im sure he would have one.
Goes by FATMAN on the forum.
Morgan, if it is any help, I braze weld the hole completely shut and then redrill the bronze to the standard clevis pin size. That means i usually get a pin running in bronze, just like it had been bushed.
