PRICE: $10.00 plus shipping.
FORD Model T rear wheel hub brake pull rod. Original part, not repro.
Ford part #3469 : Left Side (USA Drivers Side) Can be re-bent to fit right side.
Will fit 1909-1925 but this is not the early forged end type, so it is correct for 1918-25.
54-1/8” long from center to center of clevis pin holes with adjustable end adjusted to middle position. Length has not been modified from original.
Good usable condition. Some minor wear to clevis ends and some minor wear where rod slides thru anti-rattle bracket. Threads are good.
This came off a working car.
Will ship (USA only) in a sturdy cardboard mailing box. 57” x 2” x 2”, 3 pounds, USPS Ground Advantage. Shipping cost will be about $18.15 - $27.50 depending on location from zip 98146.
If interested, contact me by email thru this forum.
Tony
SOLD....FS: (For Sale) Rear Wheel Hub Brake Pull Rod.
Topic author - Posts: 23
- First Name: Tony
- Last Name: Delbianco
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout
- Board Member Since: 2022
Last edited by Tony Delbianco on Mon Dec 30, 2024 9:02 pm, edited 2 times in total.
- First Name: Tony
