1915 Centerdoor intake manifold
cchigaridas
First Name: Chris
Last Name: Chigaridas
* REQUIRED* Type and Year of Model Ts owned: 1915 Centerdoor Sedan
Post by cchigaridas » Fri Dec 13, 2024 1:00 am
I need a factory extended neck intake manifold for my 1915 Centerdood sedan. The gas tank was under the back seat and it starved going up hills without the long neck. Any help would be appreciated.
Re: 1915 Centerdoor intake manifold
Post by Mark Gregush » Fri Dec 13, 2024 8:14 am
Rare as hens teeth! This might work, not original but has a much longer neck. Don't know if he wants to sell. https://www.facebook.com/photo/?fbid=92 ... 9581385548
The alterative might be to cut the down pipe and extend it.
Stephen1915
First Name: Stephen
Last Name: Noll
* REQUIRED* Type and Year of Model Ts owned: 1916 Coupelet
Post by Stephen1915 » Fri Dec 13, 2024 9:03 am
Here is a photo of what Chris is looking for-
Robert Kiefaber
First Name: Bob
Last Name: Kiefaber
* REQUIRED* Type and Year of Model Ts owned: 1906 model F, 1907 model R, 1915 centerdoor sedan, 1921 centerdoor sedan
Post by Robert Kiefaber » Sat Dec 14, 2024 12:55 am
Mark, good idea I have thought about doing that I need one as well.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Sat Dec 14, 2024 2:43 am
Hi Chris, i sold my 15 centerdoor years ago. The one on my car was the only long manifold ive ever seen, i hope you can scare one up. In the mean time, i think id section a piece from another one in. Best of luck to you.
Last Name: Hatch
Post by Dan Hatch » Sat Dec 14, 2024 8:52 am
Just a question, was this used on any other car?
Or was it 15 only? Thanks Dan
Post by Wayne Sheldon » Sun Dec 15, 2024 7:09 am
1915 only and center-door sedan only. Due to the low flat gasoline tank under the far back rear seat in only that one model that one year. Less than a thousand such cars were produced, and maybe a few extra manifolds? So likely very few such manifolds survive.
I would expect to cut and weld/braze pieces from a couple iron manifolds to approximate one. I have brazed a few iron intake manifolds for various special adaptions over the years. That iron brazes very well and makes a strong bond.
With a little effort, one could make one nearly identical to the photo Stephen shared that once painted would look and function nearly perfect.
Post by Mark Gregush » Mon Dec 16, 2024 12:26 pm
LOL think maybe someone is smoking the wishful thinking pipe!!
https://www.ebay.com/itm/405418719539?_ ... R4yO_If6ZA
