WTB- Bosch mag drive cover
t-time
Last Name: Bruto
* REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Post by t-time » Tue Dec 17, 2024 12:38 pm
Needing a Bosch mag drive cover.
Layden Butler
First Name: Layden
Last Name: Butler
Re: WTB- Bosch mag drive cover
Post by Layden Butler » Tue Dec 17, 2024 12:51 pm
Looks like you need more than the cover. The case has been cut away ( above the center gear) so this will mount on a later non-generator timing gear cover that the oil filler extends down farther than earlier ones. All the lube will quickly exit these 3 gears thru that opening!
Tim D
Last Name: Dickson
* REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Post by Tim D » Wed Dec 18, 2024 9:35 am
I have a pattern made for casting new ones but never casted any.
