transport needed Longbranch,Wa. to northern Colorado or Duncan,Ok. swapmeet
Topic author - Posts: 1037
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
transport needed for KRW combination machine base plate from Steve Tomaso's site at Longbranch,Wa. to the March swapmeet in Duncan,Ok. ...this is only the portion of the combination machine that the head mounts on ... no legs or other components ... approx. dimensions are 12"x36"x6" ... weight of 80 to 100 lb. ... this base plate can be placed on the "top" surface to allow packing of other items inside the casting ...i will pay a reasonable fee for your help ... thank you Gene French
- First Name: Gene
- Last Name: French
Re: transport needed Longbranch,Wa. to Duncan,Ok. swapmeet
to the top again ...thanks MTFCA
It's still here, Gene !
- First Name: Terry & Sharon
- Last Name: Miller
Gene,
IF you can get it to Denver, I'll pick it up, hold it, and take it up to you when we can meet. That would save you from having to haul it back from Duncan. Assuming, it is for your use and not for resale in Duncan.
Good Luck,
Terry
Good Luck,
Terry
- First Name: Gene
- Last Name: French
Terry:
thanks for the offer ... i am in northern Colorado and would likely be on the path of anyone who would transport bed plate from Washington state ... i intend to re-purpose the iron plate as a sub plate on a short bed cnc lathe project ... just wanted the iron bed for the stability and easy machining for linear ballways and 5c Hardinge headstock ...Gene French
- First Name: Gene
- Last Name: French
Re: transport needed Longbranch,Wa. to northern Colorado or Duncan,Ok. swapmeet
still looking for transport...Gene French
