Brass clock to match Stewart speedometer F/S
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Mon Jun 16, 2025 4:28 pm
Phinney-Walker brass clock 2 3/4" OD that is the matching accessory to Stewart models 11 and 26 speedometer heads, see the 3 threaded holes in the back. This particular clock was factory modified with a rim added for panel mounting, the ring can be easily removed for bracket mounting as used on Model Ts 1911-1914. A very nice clock that will require a trip to the clock shop as it has been overwound. It may be New Old Stock as it shows no wear and no signs of ever being mounted. $125 which includes 48 state domestic shipping.
Psainslie
First Name: Patrick
Last Name: Ainslie
* REQUIRED* Type and Year of Model Ts owned: 1911 & 1919
Re: Brass clock to match Stewart speedometer F/S
Post by Psainslie » Mon Jun 16, 2025 4:45 pm
I’ll take it if still available. Mr Butler
