WTB Fun Projects/Birdhaven closed spool pinion bearing
NealW
Topic author - Posts: 506
- First Name: Neal
- Last Name: Willford
I am looking for a Fun Projects/Birdhaven converted closed spool pinion bearing. I would prefer the adjustable version, but am open to the nonadjustable kind. Birdhaven still does these conversions, but it is my understanding that the customer needs to provide a crack free housing and my closed spool has a crack.
Please send me an email through the forum if you have one that you would be willing to sell. No PM please, as I will not see it.
Thanks,
Neal
Thanks,
Neal
Adam
- First Name: Adam
- Last Name: Doleshal
Re: WTB Fun Projects/Birdhaven closed spool pinion bearing
Fyi… The area where the two housings come together often transfer a “rub mark” to the pinion housing that looks like a crack but isn’t. If this is the case with yours, it would still be a good core.
NealW
- First Name: Neal
Thanks for the information, but it is a 1" long crack between one of the holes and down the inner wall with the sleeve removed.
I have several closed spools - I'll dig one out & check it if you'd like - I don't have any early, no bump type. A T buddy of mine is doing up a new Timken spool kit but it's for the later open spool.
Yes they have a core charge. What year spool do you need. I have some. Email me via the ForumNealW wrote: ↑Wed Aug 13, 2025 9:26 amI am looking for a Fun Projects/Birdhaven converted closed spool pinion bearing. I would prefer the adjustable version, but am open to the nonadjustable kind. Birdhaven still does these conversions, but it is my understanding that the customer needs to provide a crack free housing and my closed spool has a crack.
Thanks,
Neal
The one early one I have to give up showed some hairline cracks around the outside of the lip. So its in scrap now.
Have later model spools in good shape.
NealW
- First Name: Neal
The spool is for an early 1914 T, equipped with a two piece drive shaft. Here are some pictures showing the pinion. If you mean by bumps having extra meat around each bolt hole, then yes.
I replied to your email, Neal - I have a nice one here.
NealW
- First Name: Neal
Birdhaven reached out to me and they have a core to build up an adjustable spool, so I am going that route. Thanks to those who checked for one for me.
Wingnut
- First Name: William
- Last Name: Reep
- * REQUIRED* Type and Year of Model Ts owned: 1924 roadster, 1926touring, 1926 Coupe
Steve, how much for the closed spool? Wingnut
Not sure of value - reasonable offer + the ride from Washington State.
