FS 1913 engine
Topic author - Posts: 731
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
FS 1913 engine
1913 engine standard bore #1cyl has a nice wrist pin mark it will probably need a sleeve other cylinders look good what's you are buying in the block and rotating assembly no trans pan or hogs head they will be removed. $600 Local pick up pleasant prairie wisconsin
- First Name: Karl
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- Board Member Since: 2011
Re: FS 1913 engine
E-Mail sent.
- First Name: Karl
- First Name: Ted
- Last Name: VanBeek
- * REQUIRED* Type and Year of Model Ts owned: 27 Touring, 13 Touring, 10 Touring
Re: FS 1913 engine
If you still have the 13 engine, please call me at 503-728-3476 thanks, Ted
- First Name: Karl
Re: FS 1913 engine
Ted I've called several times no answer shoot me a email if your interested
