FS - Rebuilt/ECCT Calibrated Ignition Coil Sets
Topic author - Posts: 1944
- First Name: Robert
- Last Name: Jablonski
Four freshly rebuilt Ford ignition coils in each set. Selected better wood cases cleaned and coated with linseed oil mixture, secondary and primary internal coils tested and condensers replaced with orange drop capacitors, wire connections twist and soldered...... repotted with hot tar as necessary. ..... Coil hardware cleaned and reused. New manufactured coil points, All physical mounting directions followed, and adjusted , each unit calibrated on ECCT system. ... Each set of four coils, including continental, USA. postage, are $425.00 ..... Payable only with postal money orders ..... Take note, there are four complete sets of four coils available....... If you're not going to Hershey or Carlisle, savings of gas time and money on the trip will help getting these sets of electrically balanced quality ignition coils......
Re: FS - Rebuilt/ECCT Calibrated Ignition Coil Sets
All boxes have square corners, the point bridge is parallel with the top wood. Cell phone pictures will distort image.
For those that had questions, basic purchase of each core rebuildable coil unit is $30, parts labor and calibration on each unit is $70, and packaging and postage for the set is $25. Offering is for set of four coils including packaging and shipping, payment thru USPS money order.
move to top, thanks
