'27 frame, motor, loose parts*SOLD*
Martinbuilt
Topic author - Posts: 31
- First Name: Christopher
- Last Name: Martin
- * REQUIRED* Type and Year of Model Ts owned: 1925 speedster
I'm going to be shifting some things around in the shop, so if i can re-home this soon...
Otherwise, everything gets buried until i'm bored.
No title. I wanted to build a "pig 'n ford" type racer.
Super nice frame. Clean, painted, lovely. (I drilled out the rivets, and removed the running board supports, but they are here.)
Numbers are present.
'27 motor/trans. Stuck, but i haven't investigated. I pulled the head, and there's no obvious bore damage. I'm totally new to T's, so maybe you know where to look.
Also includes rad, steering column, small-drum rear axle with wood spoke hubs, front axle, early spindles, front wishbone, firewall from unknown year (nice), a couple wooden wheels, rear spring, oval tank, and a steering wheel.
Possibly something else that i've forgotten...
I can't tell you how badly i'd like to see this together, but it is taking up a bunch of space.
Near Pittsburgh PA, $500 for everything.
Martinbuilt
- Last Name: Martin
Re: '27 frame, motor, loose parts
Still here!
Oldrusty26
- First Name: Travis
- Last Name: Melnick
- * REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT 25 runabout many misc projects
- Board Member Since: 2012
Can you send pics of the wheels ? Do you have any split rims ?
Oldrusty26
Where near Pittsburgh ? I’m south of Erie pa
micshotrodgarage
- First Name: michael
- Last Name: miller
- * REQUIRED* Type and Year of Model Ts owned: 1926 & 27 Roadsters 1927 Roadster pickup
Is the radiator and shell being sold as well?
It is a low radiator and shell. Looks good. Need to check the outlet though.
Martinbuilt
- Last Name: Martin
Everything i have is included. I found an intake and carb thursday.
The rad looks promising, although i haven't had it tested.
I'll check the lower outlet when i'm in the shop tomorrow.
Martinbuilt
- Last Name: Martin
15007. About 15 miles north of pgh.
Erie is about 2hrs.
Erie is about 2hrs.
Chris, the lower outlet is cast iron. They are more robust, and may be available as reproductions. On our Canadian cars, the top outlet is pressed steel and they rust out easily. In the absence of reproductions I have had these made in cast brass too. Your radiator looks like a good candidate to work on. They rarely come with a core looking that good.
Martinbuilt
- Last Name: Martin
Please let me know.
Martinbuilt
- Last Name: Martin
micshotrodgarage
- Last Name: miller
Thank you for the photos. I do need a High radiator for a 27 Mike
Martinbuilt
- Last Name: Martin
Happy New Year!
Is my asking price out of line?
Open to offers.
Open to offers.
SteveinNJ
- First Name: Stephen
- Last Name: Barbato
What would you want for just the frame? I'm in Northern NJ. Thanks!
Martinbuilt
- Last Name: Martin
Thanks for the question, but the goal is to make space. I'm really only interested in selling everything together.
- First Name: Austin
- Last Name: Farmer
It looks like the rear axle is from a Model A. At least the one in the pictures.
Martinbuilt
- Last Name: Martin
It is.
I have a model A project that i need to focus on. Another reason to re-home the T parts.
You have good eyes, i had to go back and look to see what was there...
Oldrusty26
That’s a good price in my opinion !! But I have space issues as well , lol , I am looking for some decent 21” demountable / split rims . Wish the weather was better though, I’d like to take a look at it .
Martinbuilt
- Last Name: Martin
Still moving my shop around. It would be easier if i owned fewer things..
Just sayin'...
Just sayin'...
CornFed T
- First Name: Rob
- Last Name: K
- * REQUIRED* Type and Year of Model Ts owned: 1920 Touring
Hi, if you’d be willing to sell just the front wishbone, I’d be interested in buying it.
1920 Touring
Martinbuilt
- Last Name: Martin
Thanks for your interest.
I'll have to look, there may be (2) front wishbones. If there's a spare, i'll send you a note.
Martinbuilt
- Last Name: Martin
Still looking for a new home.
Save me from myself.
Martinbuilt
- Last Name: Martin
Martinbuilt
- Last Name: Martin
A couple more
I have a couple additional photos, buy the files are slightly too big.
Martinbuilt
- Last Name: Martin
Your price is a bit unreasonable, too low. If I had a trailer, or was closer) I'd drive the 600 miles to buy the lot (just for the pictures of the parts) for $800 - $1000. The front axle & related parts looks great, tapered leaf rear spring, Winfield intake manifold, rear axle is incorrect , etc.. I'd negotiate a deal with the NJ member for the frame.Martinbuilt wrote: ↑Thu Jan 01, 2026 11:45 amHappy New Year!
Open to offers.
Martinbuilt
- Last Name: Martin
I have been exceptionally lucky with this stuff. $500 leaves me a little upside down, but not a ton.
My thinking was to pass it along, and make some space.
Oldrusty26
Chris , where are you located again ? I may be able to come down this weekend
Martinbuilt
- Last Name: Martin
Re: '27 frame, motor, loose parts*SOLD*
Finally found a new home.
Thanks, Travis!
Thanks, Travis!
