'27 frame, motor, loose parts
Martinbuilt
First Name: Christopher
Last Name: Martin
* REQUIRED* Type and Year of Model Ts owned: 1925 speedster
Post by Martinbuilt » Thu Dec 04, 2025 4:52 pm
I'm going to be shifting some things around in the shop, so if i can re-home this soon...
Otherwise, everything gets buried until i'm bored.
No title. I wanted to build a "pig 'n ford" type racer.
Super nice frame. Clean, painted, lovely. (I drilled out the rivets, and removed the running board supports, but they are here.)
Numbers are present.
'27 motor/trans. Stuck, but i haven't investigated. I pulled the head, and there's no obvious bore damage. I'm totally new to T's, so maybe you know where to look.
Also includes rad, steering column, small-drum rear axle with wood spoke hubs, front axle, early spindles, front wishbone, firewall from unknown year (nice), a couple wooden wheels, rear spring, oval tank, and a steering wheel.
Possibly something else that i've forgotten...
I can't tell you how badly i'd like to see this together, but it is taking up a bunch of space.
Near Pittsburgh PA, $500 for everything.
Martinbuilt
Last Name: Martin
Re: '27 frame, motor, loose parts
Post by Martinbuilt » Sat Dec 20, 2025 9:42 am
Still here!
Oldrusty26
First Name: Travis
Last Name: Melnick
* REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT etc...
Board Member Since: 2012
Post by Oldrusty26 » Sat Dec 20, 2025 8:22 pm
Can you send pics of the wheels ? Do you have any split rims ?
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Sat Dec 20, 2025 8:23 pm
Where near Pittsburgh ? I’m south of Erie pa
micshotrodgarage
First Name: michael
Last Name: miller
* REQUIRED* Type and Year of Model Ts owned: 1926 & 27 Roadsters 1927 Roadster pickup
Post by micshotrodgarage » Sun Dec 21, 2025 4:00 pm
Is the radiator and shell being sold as well?
Post by Allan » Sun Dec 21, 2025 4:52 pm
It is a low radiator and shell. Looks good. Need to check the outlet though.
Martinbuilt
Last Name: Martin
Post by Martinbuilt » Sun Dec 21, 2025 5:04 pm
Everything i have is included. I found an intake and carb thursday.
The rad looks promising, although i haven't had it tested.
I'll check the lower outlet when i'm in the shop tomorrow.
Martinbuilt
Last Name: Martin
15007. About 15 miles north of pgh.
Erie is about 2hrs.
Post by Allan » Sun Dec 21, 2025 7:41 pm
Chris, the lower outlet is cast iron. They are more robust, and may be available as reproductions. On our Canadian cars, the top outlet is pressed steel and they rust out easily. In the absence of reproductions I have had these made in cast brass too. Your radiator looks like a good candidate to work on. They rarely come with a core looking that good.
Martinbuilt
Last Name: Martin
Post by Martinbuilt » Tue Dec 23, 2025 12:27 pm
ImageFound some other things. A hand klaxon horn that works sometimes, and this radiator that may not be for a T.
Please let me know.
Martinbuilt
Last Name: Martin
Post by Martinbuilt » Tue Dec 23, 2025 4:09 pm
micshotrodgarage
First Name: michael
Last Name: miller
Post by micshotrodgarage » Tue Dec 23, 2025 8:18 pm
Thank you for the photos. I do need a High radiator for a 27 Mike
Martinbuilt
Last Name: Martin
Post by Martinbuilt » Thu Jan 01, 2026 11:45 am
Happy New Year!
Is my asking price out of line?
Open to offers.
SteveinNJ
First Name: Stephen
Last Name: Barbato
Post by SteveinNJ » Fri Jan 02, 2026 12:44 am
What would you want for just the frame? I'm in Northern NJ. Thanks!
Martinbuilt
Last Name: Martin
Post by Martinbuilt » Fri Jan 02, 2026 8:14 am
Thanks for the question, but the goal is to make space. I'm really only interested in selling everything together.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Fri Jan 02, 2026 1:41 pm
It looks like the rear axle is from a Model A. At least the one in the pictures.
Martinbuilt
Last Name: Martin
Post by Martinbuilt » Fri Jan 02, 2026 4:38 pm
It is.
I have a model A project that i need to focus on. Another reason to re-home the T parts.
You have good eyes, i had to go back and look to see what was there...
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Sun Jan 04, 2026 2:43 pm
That’s a good price in my opinion !! But I have space issues as well , lol , I am looking for some decent 21” demountable / split rims . Wish the weather was better though, I’d like to take a look at it .
Martinbuilt
Last Name: Martin
Post by Martinbuilt » Sat Jan 17, 2026 3:40 pm
Still moving my shop around. It would be easier if i owned fewer things..
Just sayin'...
CornFed T
First Name: Rob
Last Name: K
* REQUIRED* Type and Year of Model Ts owned: 1920 Touring
Post by CornFed T » Thu Jan 22, 2026 10:03 pm
Hi, if you’d be willing to sell just the front wishbone, I’d be interested in buying it.
1920 Touring
Martinbuilt
Last Name: Martin
Post by Martinbuilt » Fri Jan 23, 2026 8:57 pm
Thanks for your interest.
I'll have to look, there may be (2) front wishbones. If there's a spare, i'll send you a note.
