Raw Casting for Speedster Gas Cap Yellow Brass $10
Rodger Erickson
First Name: Rodger
Last Name: Erickson
Post by Rodger Erickson » Fri Dec 26, 2025 8:50 pm
a raw unmachined brass casting, that I believe was intended to be a gas cap for a brass-era speedster. The OD is approx. 2.7", and the walls are 0.14" thick at the bottom. They taper inward so they get thicker as you go up, leaving plenty of room to cut threads. The overall height is 1.57" approx. Nice heavy cast brass, this should look pretty good with some work. I have 4 of these available. Asking $10 each not including Shipping.
Rodger Erickson
First Name: Rodger
Last Name: Erickson
Re: Raw Casting for Speedster Gas Cap Yellow Brass $10
Post by Rodger Erickson » Sun Jan 04, 2026 3:04 pm
All of these are spoken for.
Thanks MTFCA.
