FS REAR AXLE BEARINGS (SOLD)
Mark Chaffin
Topic author - Posts: 4852
- Last Name: Chaffin
Set of four used rear axle bearings with tight cages. They come greasy and will require cleaning prior to use. Price is $60 plus $8.50 shipping per set. I have eight sets available. Mark Chaffin (951) 805-0928
Mark Chaffin
Re: FS REAR AXLE BEARINGS
One set going to Matt.
laltenhofen
- First Name: LaVon
- Last Name: Altenhofen
- * REQUIRED* Type and Year of Model Ts owned: 1926 T Coupe
- Board Member Since: 2025
Would like a set.
MotoBrew
- Last Name: Schmidt
- * REQUIRED* Type and Year of Model Ts owned: Runabout 1927
Would like a set please. text and pm message sent
New Caretaker of my Grandfathers Model T. Learning how to maintenance it, keep it running and fun drives around the New England Seacoast. Not new to working on cars and motorcycles, but definitely learning the unique things that the Model T has. It is a fun journey and am thankful to have a community like the one here to help. Cheers, Steve
Mark Chaffin
One set going to Steve.
Mark Chaffin
One set going to LaVon.
Mark Chaffin
One set to Barry. One set to Kurt.
I would want to know the size of the rollers before buying.
Mark Chaffin
Even IF the rollers had .010 wear, still far superior to the solid roller bearings. Of course these do not have that kind of wear and the price is very reasonable.
Russ T Fender
- First Name: Val
- Last Name: Soupios
I’ll take a set if one is left
Karl Von Neumann
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Mark maybe you should make a official announcement that they are usable with up to .010 wear I know that but alot of guys if they are over .004 guys won't touch them I have boxes of them guys just won't buy because of thatMark Chaffin wrote: ↑Sat Dec 20, 2025 12:45 pmEven IF the rollers had .010 wear, still far superior to the solid roller bearings. Of course these do not have that kind of wear and the price is very reasonable.
I've rebuilt many rear axle assemblies & have found the best sleeves available are a smidge larger than stock Ford therefore using a near perfect bearing at .498 - .499, install too tight for my liking - I go through mine to locate a .495 - .496 to run in the repro sleeves. I've never in 40+ years located a .500 roller !
Art M
- First Name: Art
- Last Name: Mirtes
I talked to a bearing senior project engineer who had a lot of experience with these type of roller bearings, called wound roller bearings. About 8 years ago, he recommended at least .005 inch of radial clearance at the minimum. The Chief Engineer at the time of the last production (1989) of wound roller bearings agreed. The project engineer passed about 5 years ago. The chief engineer winters in Florida and returns to Ohio in the summer.
Solid roller bearings have given good service at 8,000 miles and still going. which were installed properly. However, there seems to be an adequate number of useable wound roller bearings at this time.
Art Mirtes
Art Mirtes
Mark Chaffin
Like Steve stated. New sleeves. New axles. No problem. Cleaned and properly installed. They will outlive us all. To each his own.
Mark Chaffin
One set to Val.
Mark Chaffin
One set to Joshua.
Mark Chaffin
Re: FS REAR AXLE BEARINGS (SOLD)
Last set going to Dean. Thanks all.
They're not. (They're just better than the solid rollers...)Karl Von Neumann wrote: ↑Sat Dec 20, 2025 1:49 pmMark maybe you should make a official announcement that they are usable with up to .010 wear...Mark Chaffin wrote: ↑Sat Dec 20, 2025 12:45 pmEven IF the rollers had .010 wear, still far superior to the solid roller bearings. Of course these do not have that kind of wear and the price is very reasonable.
Even more important than size, is taper. I won't use rollers tapered more than .001/.002.
