W.T.B. Bennett brake parts. I need a drum and a center mounting widget thing plus anything else you might have.
Email me by the Forum- Thanks, Steve
TeveS-Nor Cal
Topic author - Posts: 154
- Last Name: Straw
- * REQUIRED* Type and Year of Model Ts owned: 1915 and lots of parts
Re: W.T.B. Bennett brake parts
Not aware of Bennett using anything other than the stock drum? The equalizer sold by the dealers for converting 26/27 internal brakes to pedal operated brakes should work. Just in case, so everyone is on the same page, are these for small or large drum or TT trucks?
TeveS-Nor Cal
- Last Name: Straw
I believe I have the first version of the Bennett Brakes. The drums are 2" wide. I need a drum! I have only seen this set up once, on a speedster, along time ago. I bought these parts from Chaffin a few weeks ago. I would post pictures but that is above my pay grade. Thanks, Steve
TeveS-Nor Cal
- Last Name: Straw
I did it- I posted two pictures of the Bennett brake parts I need. Only took all afternoon to figure it out!
