Tire Pump SOLD
aDave
Topic author - Posts: 354
- Last Name: Dufault
Tire Pump SOLD
Model T era single brass tube hand operated tire pump. Base is cast iron and is marked Ford. Tube is free of dings, but has obvious wear signs…must have been riding under the seat or in the turtle deck for years. It does compress air, but there is a new air hose, but no nozzle to attach to the tube valve stem – the thingamajig that screws onto the valve stem. (A rebuilding kit is available from Lang’s and others, if you plan on using it to inflate the tires). $55.00 plus shipping to your place.
aDave
Re: Tire Pump
Anyone want a tire pump? It needs a nozzle.
Jim overstreet
- First Name: jim
- Last Name: overstreet
- * REQUIRED* Type and Year of Model Ts owned: 1925 roadster pickup project, 1916 touring project, 1929 A closed cab pickup
aDave
Re: Tire Pump
Hi Jim,
I haven't rec'd your PM yet.
I believe the pump has been sold...I am awaiting payment....I will let you know by 5/12.
Dave
Dave
