I am gradually working my way to restoring a '25 TT C-Cab from parts.  This forum and the knowledge of the members has been critical in me figuring out what things are and how they fit together.  In all of my parts I found these.  Can anyone tell me what they are or if they are even part of this vehicle?  There is definitely one for left and one for right.
									What are these?
rwephill
- First Name: Robert
- Last Name: Evans
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT C-Cab
What are these?
“You don’t have to go fast… you just have to go.”
				Stephen_heatherly
- First Name: Stephen
- Last Name: Heatherly
Re: What are these?
Those are part of an accessory front cross member brace. The brackets hook over the front fender irons and a rod passes through the holes in the brackets running across the width of the frame below the radiator. The idea is to keep the front cross member from spreading. It was called Henry's neck tie. I have one on my 23 runabout. If you want sell them, I would be interested.
				Stephen_heatherly
rwephill
- Last Name: Evans
Re: What are these?
Thanks Stephen.  I would have never gotten that on my own.  I appreciate the description and the picture.
